I have to look into a new set up of a load cell fed into a HELM module (1769 series module with a Compactlogix).
I spoke with HELM and gotten no where.
I do have a 10,000 lbs load cell.
Brand: Interface, Model: 3210CDM-10K.
It is set for compression and the data from the calibration sheet reads as follows:
0 lbs-0.000 mV/V
2000 lbs-0.84466 mV/V
4000 lbs-1.69001 mV/V
6000 lbs- 2.53558 mV/V
8000 lbs- 3.381130 mV/V
10000 lbs- 4.22711 mV/V
It maxes out at 4.22711 mV/V.
Bench testing and calibration confirm that the unit is fully functional.
I downloaded the manual from HELM, looked into the programming example but it is geared towards the RS500 series.
Only the Generic setup and the I/O points mentioned for the RS5K series, vague at the most I'd describe it.
I was originally told that this expensive module would be plug n play of sorts.
I'm looking into it now and still need to do the math, conversion, etc.
I'm stuck and need some help.
I can put the module in By-Pass mode, set the toggle switch in "Config" mode and zero the readings when no load is applied to the load cell.
The next step got me big time.
After "zeroing" the toggle has to be put to "Calibration" mode.
When I do, according to HELM we need to induce a "known Load" and match the numbers via the trim pots.
I cannot induce a "known load" without equipment and the unit is already asembled.
Which means we have limited amount of space to do an in-line load cell test and compare readings.
If anyone has any logic or similar set up that are willing to share I would be greatful.
I'm out of time and the project needs to be wrapped up by Thursday so we can do validation.
I have plenty on my plate to finalize the rest of the code and this is a show stopper.
Any advice or hints??
0 lbs-0.000 mV/V
