plc storereviewsdownloads
Get the book!
If you're really looking to learn about PLCs, you NEED our book...
"Your Personal PLC Tutor - A Guide to Understanding PLCs"
Easy to read and uses 'plain' language!
Get $$FREE$$ priority mail shipping too!!!
You WILL be glad you did!!
Click Here now to order
Reply
Thread Tools Display Modes
Old July 6th, 2006, 07:49 PM   #1
Aquarod
United States
Aquarod is offline
Red face what is a cost effective PLC
Hi, it's been about 15 years since I worked with PLC's so I am sure many advances have been made.
Just getting back into it as I have been doing calibrations by hand and a sight glass and want to automate and think it should be simple, I hope.
Here is what I am trying to do, I have a tank that I fill with water 100 cm high hold for 2 min. log the level and temp of the water, then drop 3 cm hold for 2 min etc. then when I reach the bottom change I fill the tank with a differnt temp of water and do it all over again. So is there an inexpensive PLC that can control the valves the pump and has both analog and digital inputs and outputs that is easily programmed since I only have a ladder logic background?
Old July 6th, 2006, 08:02 PM   #2
Tark
United States
Tark is offline
Tark's Avatar
I would start here -
http://web5.automationdirect.com/adc...g/PLC_Hardware
Take a look at the DirectLogic 05 or 06 models they can both handle what you want to do depending on how many inputs and outputs you need.
Old July 6th, 2006, 08:05 PM   #3
Aquarod
United States
Aquarod is offline
Thank you I'll do it.
Old July 6th, 2006, 08:48 PM   #4
Terry Woods
United States
Terry Woods is offline
Automation Direct (AD).
Old July 6th, 2006, 09:35 PM   #5
Stephen Luft
United States
Stephen Luft is offline
Stephen Luft's Avatar
Much will depend on if you are doing this once or if you are an OEM that will repeat the process.
If you are doing this once only, then your cost will be higher, as a result of one time costs, such as software.
The example provided - Automation Direct, will cost you $395.00 for the software plus the cost of the controller. With others, the cost will be higher. Some, including my company provide programming software that is free of charge.
With regards to your application...are you using an ultrasonic level sensor?
The cost of PLCs is dependent on three things, number of I/O, type of I/O and quantity of units purchased.
Please note that I am employed by Entertron...a ePLC manufacturer.
Hope this helps.
God Bless,
To Terry - I believe that is the shortest post I have ever seen you do.
__________________
Stephen Luft - Eternity Sales (website) (email)
Representing: Entertron, KTI, and Wirefree CNC; (Promoting Red Lion through Entertron)
Distributing: for Kessler Ellis, KepWare, Nematron (Optimation) and Westermo
(jewishheritagerevival)
Old July 7th, 2006, 01:34 AM   #6
HenryLamboo
Netherlands
HenryLamboo is offline
Unitronics
Look also at www.unitronics.com. This OPLC has an operator interface and the software is free. Support is good.
Old July 7th, 2006, 02:45 AM   #7
Gambrinus
Latvia
Gambrinus is offline
I'm concordant with HenryLamboo. Unitronics OPLC are very easy in programming. I don't like ladder, but ladder of this OPLC is quite to use, IMHO. And you'l haven't any doubts in HMI programming thanks to OP and PLC integration.
Old July 7th, 2006, 09:49 AM   #8
Gerry M
United States
Gerry M is offline
Gerry M's Avatar
What are you using for the logging? How much data will there be?
Old July 7th, 2006, 11:18 AM   #9
Jimmie_Ohio
United States
Jimmie_Ohio is offline
Jimmie_Ohio's Avatar
Quote:
If this forum ever has a "shortest post" contest, I'm not putting any money on Ron Beaufort!
Just kidding. Ron's posts may be the most consistently thorough that you will find here. The process of explanation and examples requires great detail that Ron is always so willing to contribute.
__________________
"Invention is 1% inspiration and 99% perspiration - Edison." This explains why so many engineers smell so bad...
Old July 7th, 2006, 12:22 PM   #10
geniusintraining
United States
geniusintraining is offline
geniusintraining's Avatar
Quote:
Jimmie, I could not agree anymore, there have been many people that have given very good detail explanations, but Ron's have been classic's...if you get time check out this post on MRPLC http://forums.mrplc.com/index.php?showtopic=8180 ...Phil should start a best of Beaufort link
But I also have to say that Terry's have been very entertaining
__________________
www.PLCTrainer.net
PLC Trainers, Communication Cables and Automation Supplies, ((NEW)) Siemens S7 1200 trainers
Old July 7th, 2006, 05:25 PM   #11
TWControls
United States
TWControls is offline
TWControls's Avatar
Yes Ron has absolutely the best explainations. Many people, including me, make post that are short and to the point. I like to think of Ron's as a shotgun post. He is going to answer your question, explain to you why it is so, and answer most questions that may come up while you are working out your problem
Old July 9th, 2006, 05:43 PM   #12
Ron Beaufort
United States
Ron Beaufort is offline
Ron Beaufort's Avatar
new record?
thanks guys ...
__________________
2-B ?
Best regards, ----+----] [----+------------( )----
Ron | |
PLC Training Boot Camp | 2-B |
I once was lost, but now am found, was blind, but now I see.
Old July 10th, 2006, 10:01 AM   #13
ayman metwally
Egypt
ayman metwally is offline
Here's the link:
http://www.ind-info.com/case-studies.html
__________________
Ayman Metwally
Team Leader - SCADA
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Why pay for PLC programming software? Stephen Luft LIVE PLC Questions And Answers 267 April 13th, 2010 11:20 AM
PLC to PLC communication srik LIVE PLC Questions And Answers 10 April 4th, 2006 06:38 AM
GE Fanuc 90-30 PLC & RS232 PC to PLC Comms qee LIVE PLC Questions And Answers 7 March 2nd, 2006 09:27 AM
PLC to PLC Communication (Mitsubishi FX2N) c0met LIVE PLC Questions And Answers 6 May 31st, 2004 07:31 PM
Cost to develop a PLC program Stephen Luft LIVE PLC Questions And Answers 13 January 19th, 2003 12:08 AM
