plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old June 1st, 2008, 06:52 AM   #1
alezi
Seychelles
alezi is offline
choosing capacitor when translate 3 phase AC motor into single phase
Hello colleagues,
How it is go on, I have one question, maybe simple for some experts, I need to know, how calculate which capacitor we are need when transformed 3 phase AC motor in single phase motor, I know one formula C= 70 √P, when is C in metric units micro F(Farads) and P is power from AC motor in W(Watt),
in example: P=100w
when computing we are to receive very strange results approximately 700 micro F, of course Im informed about chart for choose volume capacitors.
Thank you for replay
Aleksandar
Old June 1st, 2008, 06:01 PM   #2
eebads2391
United Kingdom
eebads2391 is offline
Hi Aleksander ,
Your question is not clear
Please explain what you are trying to do
You can run a single phase motor from a 3 phase supply if you have a suitable/safe means of connecting it to a local distribution board
Not sure why you are requiring to connect capacitors unless you need to provide power factor correction
more information please
Old June 1st, 2008, 07:58 PM   #3
bernie_carlton
United States
bernie_carlton is offline
bernie_carlton's Avatar
I believe he's trying to do the opposite - run a 3 phase motor from a single phase supply using capacitors in some way.
__________________
Controlling outputs is the PLC's way of getting its inputs to change.
www.thePLCguy.com
Old June 1st, 2008, 09:06 PM   #4
Gil47
New Zealand
Gil47 is offline
Gil47's Avatar
Quote:
Aleksandar
The above formula is unknown to me, and when I do a google search I also find no formula like it or even similar.
We need alot more detail if you would like us to assist you.
Old June 1st, 2008, 09:28 PM   #5
leitmotif
United States
leitmotif is offline
Hello colleagues,
in example: P=100w
when computing we are to receive very strange results approximately 700 micro F, of course Im informed about chart for choose volume capacitors. Thank you for replay Aleksandar
Most confusing.
Are you trying to run a single phase motor off 3 phase and need to know the capacitor value for the motor?
ANSWER Look on the nameplate or call the factory.
Are you trying to run a 3 phase motor on single phase?
ANSWER There have been several methods to do this - you can still do any of them. BUT if motor is
3 HP or less you can get VFD to run off 120 single phase
50 HP or less you can get VFD to run off 230 single phase
WITH much less hassle and LESS or maybe equal cost.
Dan Bentler
Old June 1st, 2008, 09:38 PM   #6
TConnolly
United States
TConnolly is offline
TConnolly's Avatar
You will not achieve satisfactory results trying to run a three phase motor on only single phase with a capacitor. However, if you add a second motor as an idler motor with a small capacitor to get the second motor started, then you can achieve some marginal results. The idler motor will generate your third phase, however you won't have the motor full rated power. This set up is called a rotary phase converter, and if you search google.com for rotary phase converter you can find many websites with detailed instructions on how to set one upand how to size the ilder motor and the capacitor. For general purpose three phase motors and three phase motors on simple machine tools this is an economical and frequently used alternative.
More expensive options are VFDs and motor/generator sets.
__________________
True craftsmanship is only one more power tool away.
That's the beauty of processors, they don't have emotions they just run code - The PLC Kid.
Old June 1st, 2008, 10:39 PM   #7
bernie_carlton
United States
A couple of links I found regarding this
http://www.home.earthlink.net/~ojmsmith/
http://www.freepatentsonline.com/4792740.html
__________________
www.thePLCguy.com
Old June 2nd, 2008, 04:33 AM   #8
Sparkz
Belgium
Sparkz is offline
Sparkz's Avatar
You can run a small (personally had good results up to 0.75kW) 3-phase motor on a single phase net by simply adding a running capacitor.
C = 70 x kW (formula for 230/400V 50Hz 3-phase motors to run on a 230V 50Hz single phase supply)
For example a 0.37kW motor would require a 25F cap.
You'll have to keep in mind that starting torque drops dramatically, but for pumps or other low starting torque applications it is a simple and effective solution (so forget about running an 3-phase air compressor).
Hope this helps
Old June 4th, 2008, 03:58 PM   #9
Lancie1
United States
Lancie1 is offline
Lancie1's Avatar
Sparkz, where do you connect the capacitor? What do you connect to the remaining motor phase wire?
Old June 4th, 2008, 05:21 PM   #10
Freak
Australia
Freak is offline
Freak's Avatar
Vsd
Why not use a single phase to three phase frequency drive, should simply need to connect the motor in Delta instead of star. I have several of htese onsite and they are valiable from a variety of suppliers I use SEW and AB.
Cheers
Peter
Old June 4th, 2008, 06:07 PM   #11
504bloke
England
504bloke is offline
504bloke's Avatar
Quote:
On this side of the pond, if the motor is 3 phase star 400V connected then you would connect single phase to 2 legs of the winding in delta and put a capacitor across L and the other delta leg. Dont know if the C value is correct ( i have it at work somewhere ) its a really crude method of running a 3 phase motor on single phase, no starting torque and some motors dont like it and overheat, Normally called Steinmetz Connection from memory and i have even seen this (we do motor rewinds) on OEM manufacturer machinery!
Real crappy in my opinion....
__________________
Regards
Dave
"When you are courting a nice girl an hour seems like a second. When you sit on a red-hot cinder a second seems like an hour. That's relativity."
Albert Einstein (1879-1955)
Old June 5th, 2008, 02:35 AM   #12
Sparkz
Belgium
Sparkz is offline
Sparkz's Avatar
Hi Lancie,
Dave beat me to it in answering your question... but also Peter has a good point.
Nowadays the cap solution is only used for economical reasons: A perm cap costs around 5 to 10, while a VFD costs about twenty times as much. On the other hand, you wouldn't have to worry about torque when using a VFD, so you could run any application (up to 3kW I think?) on a single phase.
BTW, the Steinmetz connection has been around for decades, way before there were "fancy" VFD's ;-)
To Dave: We also do motor rewinds (dad started back in the late 60's).
Old June 5th, 2008, 01:36 PM   #13
alezi
Seychelles
alezi is offline
Thanks a lot for respond every body, some people think this is wonder because today we are have many ways for solve this problem like as vfd, problem is money ,one permanent capacitors is much chipper then vfd,I know all about loosing power and moment inertia when three phase motor work like single phase, when motor give us enough power it is better solution, money we are spend on others things.
And again thanks for replay,
Aleksandar
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Single Phase Inverter question eddycheong LIVE PLC Questions And Answers 30 April 2nd, 2008 02:30 AM
Start of single phase AC motor - theory and practice Pandiani LIVE PLC Questions And Answers 5 January 29th, 2007 09:49 AM
motor 3phase to single phase billyboot LIVE PLC Questions And Answers 22 July 6th, 2005 07:14 AM
single phase ac motor ushakkal LIVE PLC Questions And Answers 1 January 12th, 2003 02:24 AM
Mechanical/Material Handling and ISA 88 rlmunoz LIVE PLC Questions And Answers 6 December 25th, 2002 02:49 AM
