plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old May 4th, 2010, 04:08 PM   #1
NOUR
Canada
NOUR is offline
Angry wago 750-843 (urgent)
Hi guys,
i have a communication error whene the power-on reset!!i don't know how to deactive the bootp protocol!
codsys, 750-843
Thanks verry much
Old May 5th, 2010, 10:45 AM   #2
shooter
Netherlands
shooter is offline
shooter's Avatar
it is a switch in the resources tab
__________________
shooter@home.nl
skype shooter paul.deelen
Computer Shooter
Paul Deelen
J. Wassenaerstraat 29
NL 5224 GG 's-Hertogenbosch
+31653300739
Old May 5th, 2010, 05:38 PM   #3
KP_EENG
United States
KP_EENG is offline
Shooter is correct. Click on the Resources tab of the Project Navigator, then select Target Settings from the selection tree. When the Target Settings dialog is display, click on the General tab and you should see the selection for Load bootproject automatically.
Regards
Old May 5th, 2010, 11:00 PM   #4
dellae
New Zealand
dellae is offline
You need to use the Wago Ethernet settings program to turn bootP off.
It is a download on the site.
However it only looks for a bootP server on bootup, if it can't find one then it does whatever was in the bootproject that you set.
However if the 843 is as reliable as the 842 I would throw it out and replace it with an 841 or 871.
I have replaced so many dud 842s that won't get out of BootP mode that it is not funny.
And Wago have never come up with a solution
Old May 6th, 2010, 10:05 PM   #5
dutch@wiredboat.com
Canada
dutch@wiredboat.com is offline
750-842
I have 37 installations using 750-842.
Never any issues as described in this forum.
Old May 7th, 2010, 03:04 AM   #6
IainH
United Kingdom
IainH is offline
If there is a DHCP server on the network when the 750-843 boots up and BootP is running, it will get allocated a new IP address.
Two ways around this, don't have it connected to a network with a DHCP server or do as delae suggests and turn off BootP using the Ethernet settings tool.
It can be downloaded or it might be on the installation CD, hidden away somewhere.
You will almost certainly have to run the WAGO BootP Server program to reset the IP address to what you want/need. This should also be in the installation CD somewhere. DO THIS BEFORE DISABLING THE BootP service!!
Iain
Old May 7th, 2010, 10:33 AM   #7
WAGO Support
United States
WAGO Support is offline
There are two ways to de-activate the BootP protocol in a 750-843:
BootP can be disabled locally using WAGO Ethernet Settings. This utility can be downloaded from the WAGO website, and allows configuration of the 750-843 via a serial or USB cable to the front configuration port on the 750-843.
BootP can also be disabled remotely via ethernet, by changing the value of a configuration register in the 750-843. The configuration register (address 0x1028 or Modbus address 404137) is Modbus addressable, so any ModbusTCP driver or OPC server can access this register. The register value is 1 by default. Set it to 0 to disable BootP.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
wago 750-833 - Selected PLC profile ... problem tomofu LIVE PLC Questions And Answers 4 May 5th, 2010 02:04 PM
WAGO Profibus Master robbo56 LIVE PLC Questions And Answers 3 September 22nd, 2009 02:10 AM
Wago Addressing Problem Siby LIVE PLC Questions And Answers 4 May 5th, 2009 03:52 AM
MP277 panel on Profibus with Wago IO foreverandever LIVE PLC Questions And Answers 3 December 12th, 2007 12:49 PM
Wago Modules pogiako LIVE PLC Questions And Answers 6 January 18th, 2005 02:38 PM
