plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old November 15th, 2015, 08:38 PM   #16
JUpshaw
United States
JUpshaw is offline
Newby here, I'd like to pipe in on this old thread as well and also want to say thanks for the valuable information. We had similar issues and ended up replacing one of the boards/cards to correct this issue. I wonder if we could have made the changes to the program as mentioned in this thread. BTW - this system was running without issue for 14 years.
Old November 15th, 2015, 09:34 PM   #17
Mickey
United States
Mickey is offline
Mickey's Avatar
Programming changes are not going to fix a bad card/module.
__________________
Mickey
If you want happiness for an hour-take a nap. If you want happiness for a day-go fishing. If you want happiness for a month-getmarried. If you want happiness for a year-inherit a fortune. If you want happiness for a lifetime-help someone else.
----- Chinese Proverb
Old November 15th, 2015, 09:54 PM   #18
GaryS
United States
GaryS is offline
GaryS's Avatar
I have seen the math overflow fault set with everything normal some math functions will cause the fault. I ran into it many years ago call tech support . recommendation was to on the last runs of the code clear the math overflow bit if its set when the ladder code rolls over to rung o you get the fault. it doesn't happen every scan it depends on the result of a math function calculation.
Old November 16th, 2015, 03:14 AM   #19
JUpshaw
United States
JUpshaw is offline
Thanks a bunch fellas and really appreciate the prompt response!
Old November 21st, 2017, 10:13 AM   #20
marcrdz
Mexico
marcrdz is offline
Thank you guys for posting valuable solutions long ago, I just had downtime on some new systems I recently installed, I'll apply your teachings, just to let you know there still helpful.
I got a Micrologix 1100, Tension Control System: encoder counts, speed average, PIDs, regression speed formula, offsets, Acel and decel; so lots of math.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
AB SLC 5/05 Ethernet MSG Errors mrdegold LIVE PLC Questions And Answers 7 January 20th, 2009 12:10 PM
SLC 500 Pogram Disappear!! hhuong LIVE PLC Questions And Answers 7 February 2nd, 2005 07:03 PM
AB CTC units..with 2 SLC 5/04 DH+ Russ LIVE PLC Questions And Answers 4 December 15th, 2004 04:02 PM
OSF Instruction with SLC 50/4 Craig LIVE PLC Questions And Answers 11 April 2nd, 2003 05:33 PM
Slc 5/05 Problems ? RADKON LIVE PLC Questions And Answers 4 August 19th, 2002 03:47 AM
