plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old November 29th, 2017, 01:33 PM   #16
babido10
Morocco
babido10 is offline
Quote:
Originally Posted by JOLTRON View Post
The print("MW0=" was fitting when reading the value of of a memory location. I don't believe it would be necessary anymore. You should probably replace it with something along the lines of 'Result of writing MW10 = '
WriteFlagValue(0,0 shows what byte, bit you want to write.
So it should be updated to WriteFlagValue(10,0
None))) at the is a pointer to the data that is to be written. You can try insterting an integer or something directly and see if it errors. The example below should write 47 to mw10
I would try something along the lines of:
print("Result of writing MW10 = "+str(prosim.WriteFlagValue(10,0,win32com.client.c onstants.S7_Word, 47)))
I tried but doesn't working
Error mssg:
File "D:\simooo\plc.py", line 9, in <module>
print("Result of writing MW10 = "+str(prosim.WriteFlagValue(0, 0, win32com.client.constants.S7_Word, 47)))
TypeError: WriteFlagValue() takes at most 4 arguments (5 given)
Old November 29th, 2017, 02:27 PM   #17
JOLTRON
United States
JOLTRON is offline
JOLTRON's Avatar
Try removing the constant definition. That will reduce the number of arguments by one. But I am not sure if it will accept the actual value of 47 or if it will require an actual pointer.
print("Result of writing MW10 = "+str(prosim.WriteFlagValue(10, 0, 47)))
Old November 29th, 2017, 05:45 PM   #18
Thomas_v2
Germany
Thomas_v2 is offline
You can't write a single word, and also not a single byte. This problem with Python, pyWin32 and Prosim I have mentioned in my first post.
You can write variable with:
valueToWrite = 1234
prosim.WriteFlagValue(12, 0, valueToWrite)
The parameters don't contain any (visible) size information. But in detail the 3rd argument is a variant. A variant contains information of the data type of the variable. If the datatype is byte, then the function writes one single byte, if it's a word then the function writes a word and so on.
But every Python variable is detected as 32 bit integer variable, you can't force a datatype to be 8 or 16 bit.
You'll get similar problems when you want to write a float value, but this can be solved with struct.unpack.
The only method to write a byte or a word with Python / pywin to prosim I know, is to set/reset every single bit of the variable. But when the bits are set/reset not between the OB1 cycles, then you may read an uncomplete variable inside the plc program.
I'd use another language like C#, or write a C dll which encapsulates the prosim handling, and call the C functions from Python.
Old November 30th, 2017, 05:09 AM   #19
babido10
Morocco
babido10 is offline
valueToWrite = 1234
i used this script to write M1.4
print("Result of writing MB1 = "+str(prosim.WriteFlagValue(1, 4, True)))
It works very well
but if i tryied to write input point E2.1
print("Result of writing EB2 = "+str(prosim.WriteInputPoint(2, 1, True)))
it does not work
and if u can give a exemple for this methode:
"use another language like C#, or write a C dll which encapsulates the prosim handling, and call the C functions from Python"
Regards!
Old November 30th, 2017, 01:53 PM   #20
Thomas_v2
Germany
See Plcsim manual. It has sample snippets of how to use the S7Prosim interface from C#, C++ and VB6.
Old December 5th, 2017, 11:16 AM   #21
babido10
Morocco
babido10 is offline
When I simulated the program it gives me an error
code python(part of main program):
if okLeft: #random.randrange(2):
resultLeft = "OK"
print("Result of writing MB0="+str(prosim.writeFlagValue(0, 1, True)))
else:
resultLeft = "NOK"
print("Result of writing MB0="+str(prosim.writeFlagValue(0, 1, False)))
if okRight: #random.randrange(2):
resultRight = "OK"
print("Result of writing MB0="+str(prosim.writeFlagValue(0, 2, True)))
else:
resultRight = "NOK"
print("Result of writing MB0="+str(prosim.writeFlagValue(0, 2, False)))
return resultLeft,resultRight, imagenesProcesadas
error:
else:
IdentificationError: unexpected indent
if u can help me to resolve this problem
Regards!!
Old December 6th, 2017, 10:49 AM   #22
babido10
Morocco
babido10 is offline
Hey Thomas, thank u to help me to have solution of this problem
code python:
import snap7
from time import sleep
import struct
import snap7.client as c
plc = snap7.client.Client()
plc.connect("192.168.0.1")
plc.writeMem('QX0.0',True) # write Q0.0 to be true, which will only turn on the output if it isn't connected to any rung in your ladder code
print plc.getMem('MX0.1') # read memory bit M0.1
print plc.getMem('IX0.0') # read input bit I0.0
plc.plc.disconnect()
error line ==> plc = snap7.client.Client()
I connected with the plc but the problem stay same
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Kivy + Python + PLC + RPi DINT2 LIVE PLC Questions And Answers 7 September 9th, 2016 11:28 AM
PLC Update - Back Issues Collection Now Available! Phil Melore LIVE PLC Questions And Answers 11 October 22nd, 2015 03:17 AM
try to connect PLC via intouch wonderware b_e33 LIVE PLC Questions And Answers 1 April 3rd, 2013 09:06 AM
How to connect AC sensor and motor to PLC Zhen LIVE PLC Questions And Answers 5 April 10th, 2009 07:47 AM
how to connect a PLC to an optocoupler Sean Vyar LIVE PLC Questions And Answers 1 April 5th, 2004 11:52 AM
