plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old August 10th, 2017, 06:26 PM   #1
tubedood
United States
tubedood is offline
Kinetix Drive question MOTIONVIEW
Sorry for my first question not a PLC one but I am sure the next will be! I am having difficulty connecting to a Kinetix 300 AB drive with the MotionView browser interface. Laptop is windows 10, the cable is known to be good. Tried 4 browsers (FireFox, IE Edge and Chrome) and all start to connect then give an error about security and certificates. I will post the exact error as soon as I go try again tonight. Browsers are up to date regarding Java and such and I have fiddled with the settings regarding trusts and security. Any tips would be great!
Dale
Old August 10th, 2017, 06:49 PM   #2
tubedood
United States
tubedood is offline
Actually I have the pics of the error I am getting here, hope this helps!
Old August 10th, 2017, 08:55 PM   #3
PapaSmiff
United States
PapaSmiff is offline
The problem may be that you can't use the most up-to-date Java version for MotionView. I know Java 6 works with it and you may be able to get Java 7 to work but I made the same mistake that you described (putting the most recent version of Java (8?) on my laptop).
I've been unsuccessful getting it off and acquiring the right version.
Old August 10th, 2017, 11:27 PM   #4
tubedood
United States
tubedood is offline
Thanks for the tip PapaSmiff! I downgraded to Java 8.102 (several releases prior to the one I had originally installed) and all seems well. I tried versions 7 and 6 at first but they weren't working for me. So far everything looks good running the FireFox browser.
Dale
Old August 10th, 2017, 11:30 PM   #5
tubedood
United States
tubedood is offline
One more item that I needed to do in case anyone else has this issue was add my drives IP address to the securities exceptions list in the Java configuration application.
Dale
Old December 14th, 2017, 09:24 AM   #6
Adam13
United States
Adam13 is offline
Adam13's Avatar
I ran into this problem today for the first time and thought I would share my solution. I was able to get things working with Java version 8, update 151 without downgrading to a previous version.
The java security settings must be modified first in order to run the MotionView java applet. This can be done by running Notepad in administrator mode and opening the file C:\Program Files (x86)\Java\jre1.8.0_151\lib\security\java.security . Change jre1.8.0_151 to match the most current Java installation on your computer. Remove references to MD5 and MD5withRSA from all lines that include ...disabledAlgorithms...
Skip the lines starting with # as they are just comments. Save the file and attempt to run MotionView again.
I don't run Java on my host laptop, but rather in a Hyper-v client as there are too many security holes in Java. Editing the security settings in this manner opens Java up even further, so proceed at your own risk. It would be best to keep the original security settings file and replace it after configuring the drives.
If time and production allow, it would also be better to update the drive firmware.
Old December 14th, 2017, 02:46 PM   #7
PapaSmiff
United States
Been away for a while...
tubedood: Happy to help and thanks for the point about the IP addresses.
Adam13: You have given me insight into a problem that's been nagging at me for a while now. Thank you.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Drive Question arocon LIVE PLC Questions And Answers 9 March 28th, 2017 09:04 PM
Siemens Master Drive Question Mad_Poet LIVE PLC Questions And Answers 0 March 23rd, 2017 09:57 AM
Kinetix 6000 Drive Soft Limit Fault Action scarince LIVE PLC Questions And Answers 4 November 19th, 2015 09:43 PM
OT: AB 1336 drive question Ken Moore LIVE PLC Questions And Answers 5 April 12th, 2007 07:13 AM
Frequency Drive Question Tim LIVE PLC Questions And Answers 18 November 23rd, 2002 09:10 PM
