Kataeb Member K Join Date Jan 2007 Location www.livelovelebanon.com Posts 628 Dec 15, 2017 #1 Kindly , where can we find a pdf copy of the following document ? PCS7 on Tour Workshop v8.0 or higher Thank you
gclshortt Member Join Date Dec 2014 Location Ontario Posts 3,217 Dec 15, 2017 #2 http://w3.siemens.com/mcms/industrial-automation-systems-simatic/en/manual-overview/tech-doc-pcs7/pages/default.aspx https://automationhub.files.wordpress.com/2010/12/pcs7_workshop.pdf&embedded=true The above links may help you out. Regards,
Kataeb Member OP K Join Date Jan 2007 Location www.livelovelebanon.com Posts 628 Dec 15, 2017 #3 https://automationhub.files.wordpress.com/2010/12/pcs7_workshop.pdf&embedded=true This one is for PCS7 v6 . Hope to find another for v7 or v8 ... Thank you anyway
