plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old December 13th, 2017, 02:49 AM   #1
MHammer
Denmark
MHammer is offline
MHammer's Avatar
Question RSLogix 5k - Locking top toolbars
Hi everyone who's reading this.
I have a tendecy to move around with the toolbars in RSLogix 5000, when I have to make a fast function draw into to the ladder.
Is there any way to lock them so it does not happen?
//MHammer
__________________
Helpful? Rate it.
Solved? Post it.
Idiot? Shut up.
Old December 13th, 2017, 11:02 AM   #2
daba
United Kingdom
daba is offline
daba's Avatar
I don't know of a way to lock them, but they are easily put back where they should be.....
Go to "View" -> "Toolbars", and there's a big button on there to "Reset Factory Toolbar Layout"
Or, hold down the "Alt" key, then press v, t, and f. Then release the Alt key.
__________________
___________________________
ControlLogix & SLC Training
a-b train ltd.
abtrain@tiscali.co.uk
www.abtrain.co.uk
tel: 07506 73 9999
nil illegitimi carborundem
Old December 13th, 2017, 12:49 PM   #3
RVaughan
United States
RVaughan is offline
Go to Tools>Options, Select Ladder Editor, then click the 'Configure...' button. Set hot keys for your most common instructions. Reduced toolbar clicking, reduced toolbar movement, reduced mouse movement, increased productivity.
Old December 13th, 2017, 02:04 PM   #4
cwal61
United States
cwal61 is offline
There is no need to drag an instruction onto a rung. If your program is set to Append the instructions then select the previous instruction and click the instruction in the bar to add the instruction to the right of one highlighted. If your program is set to Insert it would add the instruction to the left side of the one highlighted. You can also use Alt+Insert to open the Add Element Window and pick you instructions from there. You can type in the mnemonic code in the formula bar. The last the one is my favorite and IMO the fastest. Especially with simple logic.
Ctrl+R adds rung type XIC INPUT1 OTE OUTPUT1
(enter) and your done. Without your hands ever touching a mouse.
Old December 13th, 2017, 04:54 PM   #5
daba
United Kingdom
daba is offline
daba's Avatar
Even faster is to just press "Insert" key - no need for Alt-Insert...
And using this, pressing the first letter of the instruction mnemonic jumps the highlighted selection to the first instruction beginning with that letter, and if it's the one you want, just hit "Enter". If it is not the instruction you want, type the second letter, ..... and so on until the highlighted instruction is the one you want.
Most times you only need to press 2 keys to select the instruction you want, sometimes 3, and less likely 4.
__________________
a-b train ltd.
www.abtrain.co.uk
tel: 07506 73 9999
Old December 13th, 2017, 05:11 PM   #6
keshik
Canada
keshik is offline
Even more fun is to use Quick Keys. (Tools >> Options >> Ladder Editor --> Enable Quick Key)
These allow you to enter common instructions with a single key. For example, type "x" to add a XIC instruction, "b" to add a new branch, and so on (you can even add your own).
Has the side benefit of driving anyone using your computer insane with random instructions popping up everywhere.
Old December 13th, 2017, 05:51 PM   #7
Jeev
Australia
Jeev is offline
Jeev's Avatar
+1 for quick keys. You can generate ladder at a decent rate of knots without touching the mouse or toolbar buttons.
Old December 13th, 2017, 06:02 PM   #8
keshik
Canada
keshik is offline
With the quick keys you can also use them to put in other instructions as well.
Type "x" to get a XIC, press the down arrow to select the instruction, press enter, and then enter the text name for the new instruction (for example, CPT).
Of course, this works best if you know the letter codes for the instructions you're trying to use.
Old December 13th, 2017, 08:14 PM   #9
Jeev
Australia
Jeev is offline
Jeev's Avatar
Quote:
Just press insert and keep typing
Old December 14th, 2017, 07:10 AM   #10
daba
United Kingdom
daba is offline
daba's Avatar
The only issues I have with "Quick Keys" are....
There aren't enough keys to cover all of the instruction set, so you can only include commonly used, or "favourite", instructions. And if you are going to do that, why not add the favourite instructions to the "favourites" toolbar. With the default toolbar layout, you can stretch the favourites all the way to the right of the toolbar area, and get quite a lot of your favourite instructions on there, and you can put them in an order that you prefer....
Once you have configured your "quick keys", you have to remember the single-letter you assigned to the instructions, which in the majority of cases can't be the same letter as the first letter of the instruction mnemonic itself. This leads to you having to remember basically 2 instruction sets....
You can configure the display to show the quick keys assignments, but I find that hard to use, because they are "listed" alphabetically by the quick key, not by the instruction mnemonic, and you find yourself trying to "speed-read" the list... Not very user-friendly, in my opinion....
I much prefer the "Insert" method, then the first letter of the instruction you want. Yes, you have to keep typing instruction name letters until the one you want appears, or scroll to the instruction if it is visible at that time, but in a lot of cases just one letter is needed.
Each to their own.....
__________________
a-b train ltd.
www.abtrain.co.uk
tel: 07506 73 9999
Old December 14th, 2017, 11:47 PM   #11
MHammer
Denmark
MHammer is offline
MHammer's Avatar
Smile I'll try enableing Quick Key :)
Thank you, for all the responses. I've tried looking into the Quick Key funtion, but i drove me kind of insane at first. But maybe I should try to enable it again.
//Hammer
__________________
Helpful? Rate it.
Solved? Post it.
Idiot? Shut up.
Old December 15th, 2017, 10:17 AM   #12
keshik
Canada
keshik is offline
Quick Keys will drive you nuts for the first few days that you use it. The biggest thing to remember to do is to hit "Enter" before you start typing tag names. If you don't, your rung is going to get very busy, very quickly
Old December 15th, 2017, 01:11 PM   #13
rootboy
United States
rootboy is offline
rootboy's Avatar
And to think, we've come so far since the days of TSR's...
__________________
Just because you can doesn't mean that you should...
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
RSLogix 5k Structured Text Editor - Show line no. MHammer LIVE PLC Questions And Answers 12 November 10th, 2017 07:33 AM
2 out of n voting block in RSlogix 5k asim_rana LIVE PLC Questions And Answers 44 January 26th, 2016 07:40 AM
RSLogix 5k and Remote Desktop Jeebs LIVE PLC Questions And Answers 16 June 29th, 2015 02:10 PM
Logix 5000 install problem smiller LIVE PLC Questions And Answers 16 May 26th, 2015 09:47 PM
RSLogix 5000 V15 Features Samneggs LIVE PLC Questions And Answers 18 April 20th, 2006 05:45 PM
