plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old January 2nd, 2018, 11:49 AM   #1
JungleKidd
Indonesia
JungleKidd is offline
How does a 4-level elevator work in a SFC ?
Hello, I'm trying to make a 4-level elevator work in SFC, but I feel kinda lost. Could anybody help me with at least the first 2 level SFC? Thank you
Old January 2nd, 2018, 04:30 PM   #2
gclshortt
Canada
gclshortt is offline
gclshortt's Avatar
http://saikat.adak.freehostia.com/pr...tor/report.pdf
The above link may help you out with the logic. The flowchart may be helpful to you.
Regards,
__________________
Garry
http://www.accautomation.ca
Connect with us on Facebook: facebook.com/accautomation/
Old January 3rd, 2018, 03:00 PM   #3
PLCnovice61
Australia
PLCnovice61 is offline
lf you go in downloads (Allen Bradely and maybe in others)on the tool bar above there are some examples, for elevators (LogicPro simulator code). They are most probable in ladder, but it will give you some idea of the code required.
But please note, that unless it was written by by Lance01, DO NOTE take it for granted that it will work as it should.
Old January 3rd, 2018, 03:40 PM   #4
RussB
United States
RussB is offline
RussB's Avatar
Q: How does 4 level elevator work in SFC?
A: Just like it will when properly hard wired.
__________________
LEARN something today so you can TEACH something tomorrow.
DETAIL in your question promotes DETAIL in my answer.
Dominus Vobiscum <))>(
"Where is the wisdom that we have lost in knowledge?" T.S. Elliot
Old January 4th, 2018, 02:03 PM   #5
shooter
Netherlands
shooter is offline
shooter's Avatar
Make a start sequence, like close doors etc.
then a split in four buttons, so you will get 4 separate programs for each button.
below them, move the cab to the wanted position, below open the doors and wait
loop back to above, and wait until a button is pressed.
show please what you have made.
__________________
shooter@home.nl
skype shooter paul.deelen
Computer Shooter
Paul Deelen
J. Wassenaerstraat 29
NL 5224 GG 's-Hertogenbosch
+31653300739
Old January 4th, 2018, 03:19 PM   #6
RocketTester
United States
RocketTester is offline
Selamat. Isteriku dari Indonesia, dan saya jalan di Ambon, Komodo, Bali dan Jakarta di Agustus 2017.
I don't think you can program it solely in SFC. SFC allows designing an overall logic flow (based upon input conditions), but I don't think it allows setting outputs. For that, you must put other PLC code within each SFC block, which can be ST, LD, FBD, or CFC, and you can use different type code in each SFC block.
Old January 5th, 2018, 01:03 PM   #7
kalabdel
Canada
kalabdel is offline
Slightly off topic. I was at the ground floor of a building and wanted to go to the second floor. There were four elevators and no buttons so I kept looking around and found a screen on the wall beside the first elevator. It had numbers on it so I touched number 2 and a few seconds later an elevator door opens up and a female announcer came on but I didn't pay attention till I got in the elevator. It said something like "ground floor going to third" and a screen inside the elevator displayed the number 3. So I wondered out loud why is it going to 3 when I clicked 2 and there were no button on the screen to touch and no physical buttons in the elevators so I could only get off at floor 3.
As you must've experienced or figured out, the elevator takes it assignment from the ground floor screen and I got in the wrong elevator that assigned to someone else who selected the 3rd floor. I was supposed to pay attention to the announcement and I think there was also a display above the elevator, not entirely sure. But until I spend more time playing with it I have to say it is typically crappy/ridged system that I encounter more and more as more tasks are being automated. Life is going to get very difficult for the next 20 years or so.
Old January 5th, 2018, 01:21 PM   #8
RocketTester
United States
To go further off topic (on a Friday),
Kalabdel's experience could be a programming glitch where the selection (floor 2) counts from 0 and actual destination (floor 3) counts from 1, though wonder how that could slip thru testing. I have seen commercial software which mixes that up, particularly in error messages. At least the system didn't force you to watch advertisements, as done in the U.S. with a captive audience at gas pumps and urinals. Some genius might go even further and make the elevator go slow to force the captives to watch the full ad. Marketers are getting desperate since people record TV shows to skip ads, learned to ignore the first paid Google search returns, and filter out ads slipped among Facebook posts.
BTW, when I program, I usually count array indices from 1, to match physical channels 1,2,... Microsoft mandated in .net that array indices count from 0 (in VB6, one could define). I still loop arrays from 1 (as humans count). I sometimes use the 0th element to store "meta info" about the array.
Old January 5th, 2018, 02:06 PM   #9
kalabdel
Canada
kalabdel is offline
Now that you mention it, when the way down there were two choices G and GR and I had to think a for a bit as to which is ground (because I have lots of time, patience and the mental clarity to spend on such things) and I clicked "G" and "ground floor" was announce which turned out to be the floor I wanted. I have no clue what GR stands.
Old January 5th, 2018, 02:18 PM   #10
bernie_carlton
United States
bernie_carlton is offline
bernie_carlton's Avatar
Garage?
__________________
Controlling outputs is the PLC's way of getting its inputs to change.
www.thePLCguy.com
Old January 5th, 2018, 02:24 PM   #11
kalabdel
Canada
kalabdel is offline
Very possible. I guest the days of P1,P2.... are gone. Welcome GR
Old January 5th, 2018, 02:42 PM   #12
harryting
United States
harryting is offline
harryting's Avatar
Ya, I ran into one of those system in DT Seattle, pretty cool.
https://www.thyssenkruppelevator.com...products/agile
Old January 5th, 2018, 02:53 PM   #13
RonJohn
United States
RonJohn is offline
RonJohn's Avatar
Still holding out for one of these myself.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
sump level control with hi level and lo level float remullis LIVE PLC Questions And Answers 10 February 28th, 2015 08:15 AM
STUDENT QUESTIONS, please post them here! Lancie1 LIVE PLC Questions And Answers 58 February 6th, 2015 07:16 PM
Control based on level and VSD Charbel LIVE PLC Questions And Answers 2 March 4th, 2014 11:24 AM
Green is Go, Red is stop, High Level Confusion robertmee LIVE PLC Questions And Answers 21 March 18th, 2008 04:40 AM
Lift problem Ladyscarlet99 LIVE PLC Questions And Answers 12 February 16th, 2004 10:39 AM
