plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old January 26th, 2018, 03:54 AM   #16
BryanG
United Kingdom
BryanG is offline
Th OP seems to have stopped responding, but I had a thought that might help someone else. A drone carrying a thermal imaging camera would be reasonably cheap and very flexible, they can fly predetermined routes and be very accurate in their GPS location. No need for cables or thousands of sensors.
Old January 28th, 2018, 06:27 PM   #17
rguimond
Canada
rguimond is offline
Quote:
Originally Posted by Saffa View Post
Is the high temperature noticeable from the surface? I know you say you have to stick the probe in, but what about using thermal imaging?
Still a manual job, but someone could just walk around with the camera scanning for a high temp.
Although if this happens under a layer of ice...
Canada sounds dangerous! Exploding frozen moss is not a hazard I've encountered before
The piles are quite thick and tall - perhaps 30' at the base and 20 feet tall. Unfortunately, the peat is a very good insulator and it prevents the heat generated at the core from dissipating, or from being detected at the surface
__________________
"If you can't measure it, you can't manage it!"
Old January 28th, 2018, 06:31 PM   #18
rguimond
Canada
rguimond is offline
Quote:
Unfortunately, it's too late by the time the heat reaches the surface of the pile. The trick is to detect the rise in temperature before it reaches ignition temperature. if the temperature gets too high, it's too late. Opening the pile will just introduce oxygen and cause rapid ignition.
The peat is such a good insulator that the temperature change at the surface is negligible.
__________________
Old January 29th, 2018, 12:08 AM   #19
keithkyll
United States
keithkyll is offline
High temperature is a result of increased biological activity. Have you considered a methane gas detector?
Old January 29th, 2018, 03:59 PM   #20
spaderkung
Sweden
spaderkung is offline
Jam a metal rod through them and measure on that.
__________________
Jon Bolmstedt, Inspired Automatician.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
How Well Do You Really Know Thermocouples Archie LIVE PLC Questions And Answers 35 October 14th, 2016 11:21 AM
Temperature transmitter cheap cornbread LIVE PLC Questions And Answers 7 August 2nd, 2013 08:51 AM
Ethernet Temperature Probe swapped LIVE PLC Questions And Answers 7 January 17th, 2013 01:26 AM
Wireless Temperature Freak LIVE PLC Questions And Answers 10 March 20th, 2009 10:00 AM
Cheap Wireless HMI Vetteboy LIVE PLC Questions And Answers 9 May 8th, 2003 03:57 PM
