plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old February 8th, 2018, 07:21 AM   #1
FactoryTalktotheHand
United States
FactoryTalktotheHand is offline
Troubles with 1769-ASCII and Labview
Working with a customer who wants to do some ASCII handshaking between the PLC (a 1769-L24ER) and Labview on a laptop. I can send data from the PLC just fine, but for some reason, when Labview sends an acknowledgement back, the ASCII module doesn't get it.
He has a serial port sniffer program up when he does this and it does send data. After some working last night, I was able to get a transmission from the Laptop to the ASCII module working, but only via YAT, a terminal program. We looked at the hex values being sent with the sniffer, and there's nothing about what YAT sends that looks any different than what Labview is sending, but clearly since YAT is working and Labview isn't, something is different.
I've tried every setting combination in the ASCII module. My baud rates are right. The code I'm using is the A-B sample code rung for rung.
I know absolutely nothing about Labview and I don't really want to. What puzzles me though is that Transmitting works with YAT but not with Labview, but Labview can receive a line just fine.
Old February 8th, 2018, 08:02 AM   #2
shawn_75
United States
shawn_75 is offline
I'd start with a loopback cable on the serial port. Transmit your data on the loopback using both LabView and YAT. See if they are the same.
Old February 8th, 2018, 08:03 AM   #3
Mispeld
United States
Mispeld is offline
Mispeld's Avatar
Is Labview sending a delimiter (e.g., carriage return) character to signal end of transmission? If so, and you are using a 1734-232ASC module, you will want to define the specific delimiter on the Configuration tab in the Receive Data frame. If not, I expect the program will need to be set up for a fixed length transmission.
Old February 8th, 2018, 05:25 PM   #4
Highland Controls
United States
Highland Controls is offline
As Mispeld pointed out, this is likely a termination character issue. LabVIEW doesn't send a termination character by default. It need to be appended programmatically. The YAT program is probably sending CR/LF when you hit the Enter button.
Old February 8th, 2018, 05:34 PM   #5
Highland Controls
United States
Don't let the LabVIEW programmer tell you he is sending the termination character because he has it selected in the Configure Serial Port VI. That is only used for reading data.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
CntrlLgx ASCII messaging Valleau LIVE PLC Questions And Answers 1 December 13th, 2002 09:08 AM
