plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old February 9th, 2018, 09:42 AM   #1
Bonn2424
United States
Bonn2424 is offline
Exclamation HELP!!! Silver suitcase test
I am looking for some help to familiarize myself with some components for a "suitcase test” that i will take next week to become an apprentice electrical technician at a major company. If hired i will receive top notch training for the position but i must do better than quite a few others. My question is: Can you provide any info on how i can use wiring diagram to determine which wires are in the wrong ports on a type of makeshift control panel?
…this will be a test that has one wire intentionally in the wrong slot. it has a few components, one of which is a relay(I’m not sure about the others, but they look similar to what you see inside a control panel. Im given a wiring diagram and asked to locate this wire and correct it, which should then power on a motherboard fan to signify completion.
Again, this is called a “suitcase test” and has 4 panels inside a large suitcase with 4 different tasks to complete in 30 minutes or so.
just to add info:
panel 1 is : wire a 3 phase motor for high voltage
panel 2 is : adjust a photo eye to proper sensitivity
panel 3 is : take a reading (from a resistor i think) using a multimeter
im somewhat familiar with the first 3.
panel 4 is : looks similar to the inside of a control panel with only 3 or 4 components, one of which is a relay not sure about the others-- and a fan on a switch that will operate once the wire is correctly placed.
I hope i have painted a proper picture and you can help. ill be forever in you debt. and my Wife thanks you as well. LOL
Old February 9th, 2018, 11:12 AM   #2
Steve Bailey
United States
Steve Bailey is offline
Steve Bailey's Avatar
You should be able to identify the components in each panel by reading the schematic. The schematic will tell you what wires should be connected to each component.
For example, the relay will need at least four wires connected to it, two for the coil and two or possibly three for each contact .
Old February 9th, 2018, 11:32 AM   #3
James Mcquade
United States
James Mcquade is offline
Welcome to the forum.
in regards to your test, they can and do change the test for every person
(been there before).
no offense intended,
if you do not understand schematic diagrams, not only are you in trouble, but you will get someone hurt.
good luck.
james
Old February 9th, 2018, 11:44 AM   #4
Bonn2424
United States
Bonn2424 is offline
Can I assume that you’re familiar with this test?
And what Should I be able to study to be well prepared to identify the components more readily?
Thanks in advance
Old February 9th, 2018, 11:45 AM   #5
jraef
United States
jraef is offline
jraef's Avatar
Interesting test, I may use that idea...
Recognize that most likely, what they are really looking for is your PROCESS for troubleshooting something. As I have taught many new technicians, the PRIME DIRECTIVE is to ALWAYS go from what you KNOW toward what you don't know. In other words, patiently run through it looking for everything that is correct, and the flaw will present itself to you eventually. If you start jumping to conclusions, guessing at things, acting on hunches trying out ideas etc., what you end up doing is creating NEW flaws that then mask the original one.
Old February 9th, 2018, 12:35 PM   #6
A_G
United States
A_G is offline
I agree, if you are given schematics, that is the first thing you should look at.
Go through each part of the circuit carefully and look for wiring that does not match the schematic.
Pick a component (for example, relay) and look at all the wiring going to it. Check it against the schematics. Then pick another component and do the same thing etc.
You can also search online for sample schematics or guides. Search for things like "how to wire a 3 phase motor", "how to measure resistance with a multimeter". Youtube might have some "how to" videos.
Old February 9th, 2018, 12:52 PM   #7
James Mcquade
United States
I have had several tests.
#1 watch the system working correctly, leave the room, come back and figure out what they did.
#2 walk into a room and use schematics to figure out what is wrong, 120 volts and 480 volts.
#3 classroom training, then go figure out what was wrong on the controls and the unit for a 161kv xray system.
#1 is when a machine breaks down, who do you ask what's wrong?
#2 is when you build a control panel and are testing it out.
#3 is the same as #1, only the controls are 24 volt or 48 volts and the machine is 161kv not 480, much more involved with are flash and hazards.
james
Old February 9th, 2018, 03:05 PM   #8
Bonn2424
United States
Bonn2424 is offline
Thank you all for taking the time to read and reply.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Problems with Siemens CP340 RS232C communication Borte LIVE PLC Questions And Answers 10 February 17th, 2010 05:16 AM
Test pen lighted when testing 24V DC? ckchew666 LIVE PLC Questions And Answers 9 August 20th, 2009 11:24 AM
OPC test Client cannot connec to RSLinx Proffesional Eric Le Yin LIVE PLC Questions And Answers 0 May 7th, 2009 11:04 PM
RS Test Stand lucifer LIVE PLC Questions And Answers 0 March 14th, 2006 10:18 AM
Test equipment ranjana LIVE PLC Questions And Answers 1 November 10th, 2002 06:30 AM
