plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old February 9th, 2018, 04:21 PM   #1
IdealDan
Malaysia
IdealDan is offline
No communication with an SLC5/04 on download
I tried and failed to communicate with an SLC5/04 using a USB to RS232 serial cable but I could not find the Driver CD that should come with the cable, COULD THIS DRIVER ABSENCE BE MY PROBLEM?​
Old February 9th, 2018, 04:30 PM   #2
Dravik
United States
Dravik is offline
Well, Yes.
But if the cable is detected enough to show the serial port in device manager, probably not.
Can you screenshot the error message? Can you 'see' the SLC in RsLinx?
Old February 9th, 2018, 04:38 PM   #3
IdealDan
Malaysia
IdealDan is offline
Quote:
Originally Posted by Dravik View Post
Well, Yes.
No, I can't see SLC in RSLinx,
Serial port in device Manager shows
sorry I didn't screen shot but "Auto configure" fails during DFI serial driver tab configuration in RSLinx.
What do you think please?
Old February 9th, 2018, 05:12 PM   #4
OkiePC
United States
OkiePC is offline
OkiePC's Avatar
Autoconfigure doesn't always work with USB to serial converters. Did you say you successfully downloaded a project to the PLC and then lost communication?
Normally, when you download a new program to a SLC and there are differences in any of the channel configurations, you will be warned and given a choice whether or not to apply those changes. Did you see this warning? If so, did you apply the changes? If the answer is yes to both of those questions, you should be able to look at the file you just downloaded to obtain the information required to properly configure your RSLinx driver.
__________________
It's not all the variables I am most concerned with, it's the undiscovered constants.
Old February 9th, 2018, 05:21 PM   #5
GaryS
United States
GaryS is offline
GaryS's Avatar
That's a common problem on the SLC5/04 it looks like somebody changed the channel 0 port to something other then the default factory settings. When that happens the only way to connect it either through the Data Highway port if you have the hardware or to reset the processor back to the factory default but when you do that you also lose all programs and data in the processor. If you have a copy of the original program stored away someplace your are good if not you may not be able to get in.
Good Luck
Old February 9th, 2018, 07:02 PM   #6
jaden
United States
jaden is online now
Depending on the RS232 adapter, you may need to put a Null Modem adapter in the serial link.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Graphite / Crimson Download Issue TimC114 LIVE PLC Questions And Answers 4 August 21st, 2014 10:47 AM
Download global safety db via command-interface (C#) rick-brinkman LIVE PLC Questions And Answers 11 October 18th, 2013 02:30 AM
BACnet communication between Kepware communication server 5.8 and BACnet Card. lalitvedak LIVE PLC Questions And Answers 0 December 23rd, 2012 12:03 AM
AB slc5/04 communication diat150 LIVE PLC Questions And Answers 7 May 1st, 2007 09:25 PM
Global Data Communication with Siemens S7-300 M/B LIVE PLC Questions And Answers 1 January 12th, 2007 09:13 AM
