plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old March 7th, 2018, 01:01 PM   #1
ma77c00k
United States
ma77c00k is offline
FactoryTalk Parameter List Value
Is there a way I can get a parameter list value passed back to the logic?
I'm using FactoryTalk Studio 9.0 ME and RSLogix 5000 v30.
I have 2 GoTo Display buttons, when the first is selected it moves a 0 into parameter #4 in the list and when the second is selected it moves a 1 into parameter #4. I have verified this works by created a text box to view the literal number of parameter #4 like so: /*LN:1 #4 NOFILL DP:0*/
The problem I have is I can't find a way to move this value (1 or 0) back to the PLC.
The only way I could think of is using a MacroTen to read the value of #4 then write to a plc tag but it doesn't work because the read side thinks #4 is a tag instead of the parameter that it is.
I hope I'm missing something obvious, thanks in advance!
Old March 7th, 2018, 01:21 PM   #2
cwal61
United States
cwal61 is offline
Use a piloted list selector. In the Value Connection put your PLC Tag. In the Indicator Connection put your Parameter {#4} In the Remote Access Connector put 1. Put the Piloted list selector on your parameter page and make it invisible. it's only purpose is to report parameter to value connection.
Old March 7th, 2018, 01:38 PM   #3
arlenjacobs
Canada
arlenjacobs is offline
Is this FT Machine Edition? If so, I think you can create an HMI memory tag to do what you need; and use the MacroTen activeX.
Create a tag named Memory\Tag0, with a default value of 0.
Then use this connection in the MacroTen activeX
Memory\Tag#4
Do the same for Memory\Tag1
If you are using FT Site Edition, then you have a few more (better) options.
Old March 7th, 2018, 02:22 PM   #4
ma77c00k
United States
ma77c00k is offline
I tried both of your recommendations but still no luck.
I attached some images of my setup, let me know if I'm missing something?
Old March 8th, 2018, 06:38 AM   #5
cwal61
United States
cwal61 is offline
This tag looks odd to me. {[#2]#3.SchedOrder.PartMode}
Are you using a parameter to identify your shortcut? Are you writing values to multiple PLC's?
I am not doubting it works just never tried it. I would suggest hard code your tag path and test again.
Also tag place holders do not work in test display mode and they will not work in Macros.
Just thinking out loud but have you tried { } around your #2 and #3
Have you checked you diagnostic viewer? Are there any errors or warnings?
Old March 8th, 2018, 09:53 AM   #6
ma77c00k
United States
ma77c00k is offline
Quote:
Yea this was the issue. I shoulda knew better. I created the mer and threw it on a PV and it worked. Thanks!
Old March 8th, 2018, 12:00 PM   #7
cwal61
United States
cwal61 is offline
If you have a test bench PLC you can put your program in then you can use the Running Man / test application. Just make sure your Design Path in the communication setup is mapped to the Test Bench PLC. Then the parameters will work. I use a local IP address for my test and a network IP for my runtime. Same shortcut two different paths.
Anyway, glad you got it working. Good luck with your project.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Can't upgrade firmware for CompactLogix L32E mabauti LIVE PLC Questions And Answers 5 October 3rd, 2017 04:08 PM
Rockwell Factorytalk exporting Parameter files rtragle LIVE PLC Questions And Answers 5 July 24th, 2015 04:09 PM
Alarm List, FactoryTalk ME einnh LIVE PLC Questions And Answers 1 January 16th, 2015 05:21 PM
Passing parameters from a parameter file into another parameter file awhite LIVE PLC Questions And Answers 0 May 30th, 2014 09:56 PM
PanelView and piloted list (Allen-Bradley) Sarlacc LIVE PLC Questions And Answers 3 May 28th, 2013 04:50 PM
