plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old March 8th, 2018, 03:12 PM   #1
n_alkopaty
Yemen
n_alkopaty is offline
Plc 2/30
Dears,
I have Allen bradley PLC 2/30 I tried to connect it to my old IBM PC with serial connection but I didn't success. I tried many connection configuration as the following:
- 1784-KTP direct connection (the message Working stay for hours without any progress)
- com1 serial to DH+ ( the message "disconnect or shutdown" appeared)
- 1784-KT direct connection ( the message "error synchrozation with communication board" appeared)
I don't know if the problem because the cable or PC card.
I made the serial cable between Db15 male and Db 25 male by myself as I don't have the orginal cable.
Old March 8th, 2018, 04:11 PM   #2
JaxGTO
United States
JaxGTO is offline
A KT card requires the following cable to go to the 15 pin DSub. Keep in mind that the 15 pin DSub is not a serial port. The 2/30 only has the special PLC 2 communications port unless you add an additional communications adapter.
Old March 8th, 2018, 04:29 PM   #3
n_alkopaty
Yemen
in my AB- computer, there isn't 62 pin port. there is a card with two ports: the first one is 9 pin and the other is 25 pin. and there is also another card with a 37 pin port in it.
Old March 8th, 2018, 07:17 PM   #4
GaryS
United States
GaryS is offline
GaryS's Avatar
What you need is a RS232 to RS422 6 channel converter.
the 15 pin DIN connector on the PLC2 is RS422
the PLC2's don't have DH+ the are just DH Data Highway
they are different and can't be interchanged
you can bridge them with the right hardware.
the attached Doc is a pin to pin cable i made and have used for years
you do need all 6 channels on the RS422 cable
the DH communication module connects to the 15 pin programming port
and you can not program them over the DH network you must be connected directly to the programming port
i use the AB PLC2 software
I hope that helps
File Type: doc PLC 2 to Computer Interface cable wiring.doc (47.5 KB, 16 views)
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Im totally new! Please help! Tool changer PLC mike^3 LIVE PLC Questions And Answers 34 November 3rd, 2015 03:28 PM
PLC Advice - Home Automation Needs onefineday2010 LIVE PLC Questions And Answers 10 July 31st, 2015 09:43 AM
Programming Omron PLC, some basic help is needed arbj LIVE PLC Questions And Answers 3 June 14th, 2015 02:00 PM
Plc suggestion aec LIVE PLC Questions And Answers 36 January 2nd, 2012 12:56 AM
PC to PLC Protocol TheRixta LIVE PLC Questions And Answers 13 December 17th, 2008 12:56 PM
