This board is for PLC Related Q&A ONLY. Please DON'T use it for advertising, etc. |
If you're really looking to learn about PLCs, you NEED our book... "Your Personal PLC Tutor - A Guide to Understanding PLCs" Easy to read and uses 'plain' language!
Thread Tools | Display Modes |
#1 |
Got a press from our sister company. When powered back up PLC was not in run mode. Tried to go online to change and got communications timeout. CPU is a TI 545-1102. Replaced with one in stock. Same thing. Replaced with a second in stock. Also the same thing. Pulled out a 545-1101 from an existing system and installed. Was able to get online. Dip switches were all set to ON on the 545-1102 as was the 545-101. Using DOS based TISOFT 2 Release 5.0. Any ideas would be appreciated.
__________________
"I think it plugs in here." |
#2 |
Guest
Posts: n/a
You did not say if you were running TISOFT on a Windows PC or not. I suspect the baud rate is different with the switches all set the same on one CPU versus another. If this is true, running TISOFT on a Windows PC may be causing you to experience problems at the higher baud rate. Try using a DOS PC or setting the DIP switches to a lower baud rate.
#3 |
Every once in a while I have experienced this with TI 50 & 505 series PLC's under TiSoft. I have had fewer communications problems since changing to SoftShop 505. Now I wish I could say the same for TI's 500 series Basic Modules...
#4 |
Yep, I agree with TR Gunderman. Working with TISOFT on Windows rather than in true DOS mode can be a problem. I always use true DOS mode now and have not had a time-out problem since.
Steve |
#5 |
Thanks for the replies guys. It ended up being that the cable I was using was only using the Rxd and the Txd signals. Evidently the 1102 CPU uses the other handshaking signals to communicate with the PC.
__________________
#6 |
![]() Join Date: Nov 2004
I have tisoft 2 release 4.3 base MS DOS, and I need to make a print but I cant. Same body know what can I do for make a print.
Luis Armando Garcia R luisarmando.garcia@crbard.co m
#7 |
![]() Join Date: Apr 2002
Luis,
See the new thread I started under your name... |
#8 |
samebody have a manual for TISOFT base MS DOS that can help me alot.
| Bookmarks |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Ti 545 to a Marquee | ilikbeer | LIVE PLC Questions And Answers | 11 | March 15th, 2005 05:59 AM |
| AD 250-1 CPU How can I reset-erase this CPU so I can use it with a NEW program withou | Anibal Hernandez | LIVE PLC Questions And Answers | 14 | November 27th, 2004 07:19 PM |
| Information TI Soft 405, TI Sof 425, TI Soft 245 | Aafke | LIVE PLC Questions And Answers | 1 | October 9th, 2003 09:20 AM |
| Changing from Melsec A3H CPU to A3A CPU | Ptilou | LIVE PLC Questions And Answers | 3 | October 2nd, 2003 06:56 AM |
| Ti 545 | larrylolson | LIVE PLC Questions And Answers | 1 | June 26th, 2003 09:01 AM |
