pcs7 training kit???
redautomation
Aug 2013
istanbul
23
hi.i want to buy plc's for training pcs7 in my company. could anyone help me what i must buy??
i think a set of s7 300 and a set of s7 400 with their profibus and ethernet module is good for start. could we train pcs7 only with 2 set's of s7 300??? or we must buy at least one set of s7 400???
because s7 400 is very expensive. thank u all
Siemens sells PCS7 box as a starter system. This can be used for very small small systems and not just as a training system. http://www.automation.siemens.com/m...rodukte/systemkomponenten/en/cs_box_EN_v2.pdf
The PCS7 box system can come with a PC based controller that you can develop PLC code on.
I would say that you need to decide if you want your training system to mimic your real world system or do you want something to develop the concepts on.
Thanx
We only want to develop the concepts and test the pcs7 capabilities. We only want to train basics of a dcs systems. We have a s7 300 with profibus and ethernet module. Now i need help to buy another parts of a dcs system. And also we cant buy dcs boxes in our country.
Does anyone have an example project of the cm ptp ET200 SP HA with 410-5H DCS (PCs7 9.1 SP1) for MODBUS MASTER/SLAVE communication ?
123
Hello, Is there a sequence when installing both TIA Portal and PCS7 in the same PC? First TIA and then PCS7 or viceversa? Thanks in advance.
484
Hello, I'm currently working on a project involving both PCS7 (v9.1 sp2 upd1) and a Panel Comfort system. This necessitates the use of TIA Portal...
789
I'm coming from a background of PLC ladderlogic/rockwell products. I am new to blocks. Can you point me in right right direction? What I would...
1,557
Hello everyone, i would like to read in pcs7 v8.2 the actual day of the month(ex 1 or 25 of the month) i used as attached read_CLK AND DT_DATE but...
1,932
