whuff
We have conveyor rollers that are used to move product in the process. The rollers are tracked via the plc (PLC5) on the linear footage of product run across them. There are 16 positions, #1 to #16. When the rollers reach a certain point, they are moved from one position to another. For example, #3 can become #8 or #5 depending on the wear diameter. After a certain time they are disposed of. The operators have a current FactoryTalk SE screen that tracks the footage. The screen has button that allows the operator to acknowledge roll changes and moves the current value into the previous value column. The issue lies in when the roller are moved from one position to another. The historical value is then lost. My two options are changing the numerical display to a numerical entry or creating a complex indirect move commands. As any roller can be moved to any other position (i.e. #4 to #6, or #4 to #2), I cannot set up an easy move command. Numerical entry is not desired due to operator error. Does anyone know of an easier way than the indirect addressing to move values (i.e. think windows cut and paste function)?
