![]() ![]() ![]() ![]() This board is for PLC Related Q&A ONLY. Please DON'T use it for advertising, etc. |
#1 |
![]() ![]() Join Date: Apr 2003
Communicate Citect 2016 with Siemens S7 1500 with S7TCP driver
I need to know the steps to communicate Citect 2016 with Siemens S7 1500 using S7TCP driver.
Thanks |
#2 |
![]() ![]() Join Date: Apr 2016
S7TCP Help
Look for the file S7TCP.chm on your hard disk, or download the driver from here:
https://www.citect.aveva.com/attachm...00_RELEASE.zip Extract the files, then open the S7TCP_1.10.00.000_RELEASE.exe file with Winzip or WinRAR, and extract the \Drivers\S7TCP\S7TCP.chm file.
__________________
Freelance Automation Programmer |
#3 |
Thanks, sigmadelta. Yes, I have that driver already, but what I need is what should I have to set up in Citect to get the communication with the S7 1500 PLC using this driver
Regards EP |
#4 |
S7TCP Help
The attached pdf is from the S7TCP.chm file.
__________________
Freelance Automation Programmer Last edited by sigmadelta; February 11th, 2019 at 03:54 PM. Reason: Added Variable Definition Help to attachment |
#5 |
#6 |
Hi sigmadelta. I am getting #BAD when I try to read a REAL value from DB20 in S7 1500 PLC. What is the meaning of "<symbolic name>" for address format?. Do you have a real example of Citect configuration , so I ccould follow it?
#7 |
<symbolic name> is the symbol name of the DB and DB item. I don't have an example, and I haven't used this specific driver, but try this...
Example: If your symbol name for DB20 is "MyData" and the REAL data item is called "MyValue", try using MyData.MyValue for the address of the tag, or "MyData".MyValue, or "MyData"."MyValue" as the address of your tag.
__________________
Bookmarks |
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
Thread Tools | |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
Citect comms to TI545 via Siemens CP1613 | labroy | LIVE PLC Questions And Answers | 4 | August 12th, 2014 01:22 PM |
Siemens S7 1200 driver specific addressing | bennyk@37.com | LIVE PLC Questions And Answers | 0 | December 9th, 2011 06:13 AM |
Siemens TCP/IP Driver to communicate with PROFINET CPU? | natirm | LIVE PLC Questions And Answers | 4 | February 5th, 2009 07:43 AM |
Siemens S7 hardware Structure Designe | farrei | LIVE PLC Questions And Answers | 10 | August 28th, 2008 04:59 AM |
AB panelView Plus MMI with Siemens S7 314 | iknowsomeplc | LIVE PLC Questions And Answers | 0 | November 18th, 2003 01:52 AM |
