Terminal Blocks
jgreenewv
Aug 2002
New Mexico, USA
242
Hey, all you panel builders out there. Has anyone used terminal blocks from Automation Systems Interconnect (ASI) before? I've been using A-D blocks, and am completely happy with them, but ASI sent me a few samples. They appear to be fairly good blocks, and the price on most stuff is a little cheaper. Any comments?
Joe
Joe,
We dealt with them for phoenix style blocks...not the panel mount. The product is good, but they don't manufacturer it. Depending on what you order, you may run into delivery issues. Once set up on account, their terms are net 15.
Have never dealt with AD, so I really can't offer a comparison.
Hope this helps.
God Bless,
Stephen,
How was their delivery typically? We usually stock some standard sizes, so that shouldn't really be an issue, unless it runs to weeks or months. Thanks.
Joe
Joe,
It depends.
The manufacturer of the terminal blocks we used were manufactured in Italy. We ran into some problems during the summer because they didn't carry sufficient stock when we had upticks in demand. During the summer the manufacturer would be shut down for a month, so we had to scramble at times.
It will depend on who the manufacturer is, how popular the part is and how much they actually stock.
Sorry I couldn't provide any better information.
God Bless,
I'm trying to include MOVs and fuses for solenoid PLC outputs in a panel with limited space. Does anyone know of terminal blocks that have built...
226
What is the difference between Siemens terminal block 6ES7193-6BP40-0BA1 and 6ES7193-6BP40-0DA1? Can they be used interchanged for an analog...
1,220
Currently using a AB 1492-FPK2, plug in fuse but now finding alot of these are.. touchy with connections. the terminal block they are plugged into...
1,352
OK, some internal "discussion" going on in my world about what is preferred in the industry for a three position connector, a spring clamp type or...
42
15,980
Hello, A couple of questions regarding NEMA schematics and terminal block labeling. 1) I am familiar with the DIN designations for components...
3,092
