I've encountered a fairly new MiCOM protection relay that for some reason can only accept firmware updates via a 25-pin parallel printer port. The engineering laptop on-site is a Windows 7 machine and I'm having trouble getting an LPT port set-up for the installed MiCOM software to use for comms to the relay.
I've tried using a USB-to-DB25 cable, but apparently that's only meant to be used for printers as the driver installed is a USB printer driver rather than a virtual LPT port. I've tried redirecting LPT1 to this virtual USB port as way to 'trick' the laptop, but to no avail. As it appears the cable driver is only limited to sending printer commands.
Are there any LPT-converters that allow me to send raw data in the same fashion as a USB-serial converter and can run in a Windows 7 environment?
Thanks.
Thanks.
