Can you change the subnet on RSlinx Enterprise Like RSlinx Classic?
JeremyAdair87
Jun 2014
By International Airports
64
On rslinx classic I can change the subnet mask. At my plant I have 3 ip ranges (10.136.8.xxx through 10.136.10.xxx) with PLCS on them. In classic I just change the subnet to 255.255.240.0 and it scans the first 12ish (I forget its not important).
On enterprise I cant find the section to fool with my driver subnet masks and gateways.
I tried Google/pdfs and found some stuff in factory talk admin console but it did not allow me to change anything that I am searching for.
Thanks,
I found another way and just came back to update. Inside the factorytalk admin console you can make a driver for enterprise and name it what you want. If you right click the driver you can "add a device " Its just a device type with an IP and no subnet mask. I tried it and got what I wanted which is --not changing my PC's static IP address over and over again and getting to see all of my HMIs to download to.
Thanks!
It seems to work like the ETH driver in classic instead of the ETHIP driver which ( one requires manual IP, one scans)
Hoping someone can give me some guidance or confirmation of what I need to do. We have a FactoryTalk SE program that I need to change the IP...
77
Hi. Rockwell learning curve 132-1b. I was having trouble to change IP address on a EN2TR. Finally found out that I need to change the IP...
747
Hello guys, How can I change subnet mask on ET200. It is grayed out. I am using TIA 14
2,325
Hey all, i have a panelview screen (image attached), with 4 items on it. Program 1, Program 2, ...3, ...4. The PLC i am using is a compactlogix...
169
Greetings I have a problem, my system is the following: wincc v8.0 (demo), logo8.3, abb m2m analyzer. I created some pages to display the...
61
