Wonderware Intouch 10.0 - Mouse cursor and popup window! How to do?
Missy5
Jul 2008
NG
24
I was wondering if it is possible to do an object that when you go cross over with mouse cursor a popup window appears?
Similar if you have one button and when you click on it the popup window opens.
Thanks, M.
Under each button or object, you can use the tooltip function to popup a bubble with a custom message. If you need more complicated controls for popup windows and controls, use the variables $ObjHor and $ObjVer in a condition script to detect if the cursor is at a particular location.
make an object "under" what you wanna mouseover. I'm pretty sure there is a "on Mouseover" condition type for the Action tab to open a window/popup.
Show "popup";
for the heck of it.. I made a mouse over object..
then put a mouseover object with a longer time on the popup to
Hide "popup";
OR
made a tag to hold a value
on mouseover object
popup_var = 1
Then wrote a script condition
popup_var == 1
on true
show "popup";
While true (800ms)
Hide "popup";
popup_var = 0;
This makes the popup come up for a set period.. 800ms evertime you mouseover
I have a somewhat similar question about a mouse over script. I would like to just show the tag name of the device that the mouse cursor moves over such as an actuator tag name. I'm not too familiar with scripting so I'm looking for a little help.
The same as what davew mentioned use the tooltip function but you could just use the static text option.
Use Tooltip animation, with an expression using the .Name dotfield of the tag. This will give you the actual tag name in the PLC.
Hi guys, I have experience with PLC to Excel etc...just starting on using intouch scada screens. I have an Excel sheet that uses mainly...
139
Hola chicos. Tengo un problema con el driver de comucicacion dasabcip 5, y un plc controllogix v34, ya realice la comunicacion pero en ciertos...
155
Hi, I am upgrading a Wonderware SCADA form version 9.5 to version 23. I am able to migrate all the graphic, but when to activate the runtime this...
407
Hi all, I am using OI.GATEWAY.2 to communicate to the PLC using an OPC UA. I can see the tags using an OPC explorer connecting to the...
181
For a while, I have been working with InTouch 10.1. The problem I am currently facing is the need to implement certain functions that do not...
478
