sparkyinak
When given the choice, do you program safety inputs such as stop buttons and overloads as normally open or closed? For example the basic motor starter circuit get wired with the stop and OL normally closed so when either one opens, the circuit deenergizes. In a PLC program, they can be programmed either way and the field wiring would need to be wired accordingly.
I have seen these inputs program both ways. Strictly out of my curiosity, how would you program a safety input, open or close, and why presuming the field device can be wired either way too?
I would when given the opportunity to, I would program them as open and wired the device normally closed. This way if the circuit is compromised or open for an emergency, the process would stop. If wired "backwards"
