Binary Inputs for Tool ID recognition
May 2011
South Carolina
87
Good morning all. I am stumped as to why my logic isn't working, other than I am not logical. I am using some inputs to turn on some N7 bits in a word to assign a Tool ID to a tool based on which inputs are made. The inputs are showing energized but the N7 bits are not showing "energized". I did a "Find All" to make sure the N7 bits were not used anywhere else, and they aren't. See attached screen shot of the logic and Find All search. Any ideas as to why the bits aren't turning on?
The most likely reason is, as suggested by the two previous replies, that this ladder file [LAD 37] is never being run.
Search for U:37; what do you find? You should see summat like this:
ADQ104: Why input file not being "energized"?
If it's make you feel better, I will make this post to be ADQ104 in my running series.
Just had the opposite, I was simulating a program, where I wrote a simulation block to simulate the machine so I created a block where the I/O is mapped, normally this is disabled or not called while simulating, however, I was tearing my hair out while trying to simulate as it was not doing what I expected. The problem, I had left the call in for the I/O map so the real I/O was overwriting the mapped bits Doh…. So even after 35 years can still forget.o_O
I've sat and looked over all the logic and started in on the hardware until I realized I was off-line. Maybe that's why my values weren't updating and OTE's weren't going true. Duh.
Happened more than once.
Hi folks, I'm trying to parse a binary string on a Red Lion DA30D using a Raw UDP/IP input port. I've done this before with ASCII strings so I do...
38
977
So here's my situation, I have been tasked with modifying the logic to mimic a button press in the PLC. I have two identical machines however one...
538
Hi, I want to extract every second bit of a double word and place it in a new word but the position of placement should be from 0,1,2......15...
17
3,066
Hello, I am trying to convert a incoming string that is in Binary format (See attachment) to a DINT. Any ideas? When I use the STOD command it...
2,208
How can I read individual binary bits from a SLC500 within FTH SE? With the Tag Browser I can get to the Binary Files and get each Integer from...
1,603
