Good Morning ,
I need to use a shift register to keep track of good and bad parts . As a rough draft I'm using 300 bits. When the 1's and 0's are going thru , eventually I'm going to run out of bits.
I don't want to zero all bits , because I still need the results behind.
Example
000010000000001000000001000001000000100100000
^ < < < < < < < Wrap Around < < < < < < < <
Beginning__________________________Dump Gate
My question is , how do I wrap around to the very first bit with new results , but keep the results that were coming behind going to the Dump Gate ?
Thanks so much in adavance
Example
