Omron CIO 54 Value
JuanPLC74
Feb 2017
Houston
23
I am modifying this program on a CJ1 Omron PLC.
CIO address 54 is under one MOV command that assigns it a value.
For the rest of the program that value is checked against other values with =(300)
However this address takes the value then start swinging between the assigned value and 0.
nothing else on the program is assigning a value to 54.
Is there a way to know where this assignment of 0 is coming from?
it is probably attached to a devicenet node, anybody knows how to take the node out of configuration
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
206
Hi There, I have couple of Omron PLCs connected on my kepserverex and my intouch reads data from kepserverex. I have been observing that roughly...
129
Hi dear . I have a system with cj1m cpu11 etn. previously NT 5z HMI was connected with plc. recently my old HMI got damaged. I want to replace it...
223
Omron AD081-V1 Analog Input Card Offset & Gain Adjustment Entering Adjustment Mode 1. Set the input card in adjustment mode (Turn ON Dip SW No-1)...
80
I am working on a project using a NB screen and NX1P2 PLC. I am having a really hard time getting a real number to properly translate through to...
120
