GuardLogix 5580 (L81ES) - safety over embedded port?
pegla00
Jul 2015
Toronto
Hi All,
I've been using this processor that communicates with safety I/O (attached to 1734-AENT) over 1756-EN2T Ethernet card.
The client now wants to add safety produced/consumed communication to another L81ES over embedded Ethernet port.
I am not sure about this. The docs say it is for I/O, motion but not for safety.
What do you think?
Thanks.
GuardLogix 5580 allows for safety over the prod/com tags. Reference Rockwell document: https://literature.rockwellautomation.com/idc/groups/literature/documents/um/1756-um543_-en-p.pdf
Page 177 and go from there.
You will need to have the Safety Network setup correctly and make the tags specifically as safety Produce Consume tags. Do not use normal tags for this operation.
I would also test the safety network in the event of a disconnected cable between the two controllers. Not a fun test, but something I would do in a controlled environment.
If Rockwell claims it's rated for safety, I believe them. But always use your best judgement and consider the risk involved in the risk analysis of what they are protecting against. Is it a common hazard? Is there a significant risk to life/limb? A Guardlogix without a safety partner is rated for SIL 2.
To add anecdotal evidence to Megabyte's excellent summary: I have done safety produced/consumed over the embedded ethernet port of a 1756-L81ES before and it (a) worked, and (b) was validated by an expert third party safety validator.
To hopefully add: an Ethernet port is an Ethernet port, unless we’re talking about redundancy. EtherNet/IP safety features are handled by higher-level CIP protocol objects on Safety/EIP devices. Your choice of port or module might have an impact on the safety response time.
Hi... I have what is so-called "Limit Values" placed in the Safety PLC. These values ​​were written in REAL safety tags format. It turns out...
418
Many of us, I'm sure, may have received this Product Notice from Rockwell. I'm just posting it up for others not in the loop as these safety...
1,491
Hi all, We tried to setup the hardware onto a 10 slot rack as follows, PS Slot 0: 5580 controller Slot 1: Safety Partner Slot 2: Safe Inp Slot...
2,714
Hello members, We have a Guardlogix 5580 with the below hardware configuration. (Guardlogix 5580 (has one eip port) -- Safety Partner --...
1,645
gents, I am trying to configure communication with EMERSON PK300 controller through port A1 using generic ethernet communication module . I could...
85
