Need help regarding factorytalk view se alarm internal sound
souviknaskar
Apr 2010
kolkata
21
Dear Memners,
i have an issue regarding factory talk view alarm sound, i have set internal bell for sevarity =1, internal speeker are working fine but internal sound for alarm not genarated. i am using ftview 9 series standalon system .
Please guide me how to active the internal bell for alarm.
Thanking you.
Regards,
souvik
For some reason, the internal bell function stopped working with version 6.0. Here is the Tech Note describing the issue.
https://rockwellautomation.custhelp.com/app/answers/answer_view/a_id/122207 (Note that you must have a TechConnect contract to view these notes.)
Rockwell has never issued a fix. I suspect this was due to the intended migration from FactoryTalk HMI Tag Alarms to the newer FactoryTalk Alarms and Events method of performing alarming. They do suggest that instead of using the internal bell, that you instead choose to play a .WAV file. There is a Tech Note on this.
https://rockwellautomation.custhelp.com/app/answers/answer_view/a_id/29298
You might want to consider moving away from the HMI Tag Alarms and start using the Alarms & Events instead. I believe version 9 was the last version to support HMI Tag Alarms. Alarms and Events is a newer method of alarming and offers a lot more capability. Playing a sound is quite easy with this method.
https://rockwellautomation.custhelp.com/app/answers/answer_view/a_id/60568
OG
OG
Thanks for reply , but i have running system its not been possible to shift hmi tag alafrms to server alarms.
i have t add on exgistion hmi alarm server .
Please guide my how i can add on hmi server alarms internal bell.
Dear Sir, I am never work on DHRIO network please help me how will be the massaging for attached configure network. Thanking you. Regards , souvik
1,416
I can’t able to get data from IN16I analog card, signal type 4-20 ma System configuration Rack 1 Slot-0, L551 CPU Slot-1, BSN Rack 2...
2,070
Ok I was not sure where I could post this or if there is any answers on this site. But I hope someone can help. I have an older Burnham B3...
2,674
Dear Guys I need help regarding PLC. I am stuck for some days now and problem is strange. Machine PLC has two encoder modules when machine is...
3,034
hi guys. currently doing my project regarding PD in PLC. My PLC is panasonic FP-X C30R. I need to know how am i suppose to have a PD controller in...
2,000
