Ilhomjan Member I Join Date Feb 2017 Location Asia Posts 1 Feb 7, 2017 #1 Hello I want to learn about PLC and INVERTORS step by step Please help me I am Electrician and I got fired my job now I want to be Automation Engineer FIRST of all what should i read or watch?
gclshortt Member Join Date Dec 2014 Location Ontario Posts 3,217 Feb 7, 2017 #2 You should select the hardware that is common in your area. This way it will be easier to gain employment. If you require some general information, here is some on PLCs. https://www.youtube.com/watch?v=r5IY4P2hHqU&feature=youtu.be http://accautomation.ca/programming/plc-basics/ I hope this helps you out. Regards,
