analog
James Simpson
Dec 2016
Kilmarnock
Good day
Would you please help, I have a 3 way valve ,it is 4-20ma controlled using a PT100 for the temperature, there is also an external input for the set point , how would I program these to control this valve to open and close using a Step 5, 135 PLC ,
Regards,
Jim.
Jim, you would have better luck if you used something that most of the members of this site can remember... the 135u has not been made for a long time, can you use a new CPU? like a 1500 with TIA Portal software?
do you have a analog output on the PLC?
is the valve having the control program or is it separate and you have a Pt100 input and a analog for the setpoint?
Good afternoon, I am currently working with an HMI/PLC LP-a070 and I require at least one analog output, but the PLC does not have one. I was...
Hi all. Customer wants analog faceplates really bad, even if we explained that it doesn't make much sense in his process. What he wants to see...
92
I'm having trouble calming down 2 Tempo Sonics. I'm using Studio 5000 CompactLogix my Raw value is jumping around from 8575.0 to 8755.0 at a...
30
1,099
I cannot add SLC500 analog input tag (I: 8.3) to EZSeries Touch Panel Editor (V 5.3). I used all the listed tag datatype but it all says "Invalid...
248
Hi, I have questions. I have Analog Input that need to put into Ignition Designer. But I don't know how to put?
109
