Keep getting timeout error from a panasonic FP0 Nais plc
capsol
Mar 2017
mexico
So I started working on this old italian machine and it has an FP0 plc, I am using the fpwin gr 2.7 software and it lets me connect to it and upload the program but as soon as I run the machine or start sending more signals I get a timeout error disconnected and have to restart de software. I am doing this from a virtual machine so I dunno if it has something to do with it.
Could anybody help me with this? Even a hint would be great.
Thanks, also I am doing my first post even thou I have been reading you for 6 years.
http://www.clrwtr.com/PDF/Panasonic/Panasonic-FP0-Manual.pdf
From the above manual:
"Extend the timeout time of the programmable display using the GTWIN. (The default setting is 5 seconds.)
Select “Transfer” from “File” in the menu bar. The “transfer data” screen will open. Select “Condition” to open “Communication Setting” screen. Change the value for “Timeout”.Click “OK” button to complete the change of setting."
This may help you out.
Regards,
Regards,
So I forgot password for t he other account, anyway now on topic. That was the first thing that I tried and it didnt work. At the end i discarded possible solutions and found out that my chinese 232 converter was sucking, so I changed to a keyspan and that fixed everything.
Anyway thanks for the help.
Have a remote lift station that uses an Ethernet connection to talk to the building right next to it, and from there it communicates via radio to...
4,537
Hi, In the last month me and collegues have experienced problems when connecting to Beckhoff PLCs with Visual Studio. After logging in and...
2,239
Good Afternoon, I'm trying to do online edits on a SLC 500 5/05 . After I put my instruction in , I keep getting " Test Edits Failed " ...
3,728
Hi all, I'm trying to use the Data Preserve Tool for Logix5k (CompactLogix controller) but I keep getting comms errors and I'm not sure why. I've...
4,055
Hi guys, I am a total newby in PLCs, and I am currently doing a project in RSLogix 5000, using RSEmulate to Emulate the PLC, details below...
15,850
