We have configured a 353 controller with an ODC block accessible via Modbus. We can access all the readable registers and the data retrieved is correct.
The customer would like to remotely change the setpoint of the controller which is Input S. The manual indicates this register is R/W but when the customer writes to the register the value does not change.
Currently Input S of the ODC is configured to receive it's value from a loop Setpoint block. I read in the manual that if Input CL in not configured changes to loop data can be made from a network command or the local faceplate. Input CL is unconfigured for this ODC block so the implication is the loop data, namely Input S, can be changed by either means.
Suggestions?
Suggestions?
