chandrapaul Member C Join Date Mar 2016 Location bangladesh Posts 119 Jul 22, 2018 #1 Hi,I want to add a CPU that is not present in the library of TIA portal . Does someone can helpme ? i am using tia v14.
JRW Member Join Date Jun 2002 Location South Carolina Posts 2,301 Jul 22, 2018 #2 What cpu? Need details! And firmware
kalabdel Member K Join Date Feb 2015 Location Ontario Posts 1,108 Jul 22, 2018 #3 chandrapaul said: Hi,I want to add a CPU that is not present in the library of TIA portal . Does someone can helpme ? i am using tia v14. Click to expand... What JRW asked and which version of TIA 14, I *think* the with the basic version yo have access only to S7-1200.
boneless Lifetime Supporting Member + Moderator Join Date Feb 2008 Location OKC Posts 1,628 Jul 23, 2018 #4 If your TIA supports the model you are wanting to add, you can install the HSP support packages. Or use the update tool. Some of the newer CPU's are not supported by the older software. And as mentioned, some are restricted by what license you have.
