passwordg
Seconded. This is a fantastic device.The easiest way to send ASCII data from AB to serial devices over distance.
You only have to load the ASCII string(s) into a single string tag in the PLC.
The RTA 435 will handle the serial part.
Flawlessly Robust.
http://www.rtaautomation.com/product/435nbx-2/
We used dozens for ASCII inputs from scanners, and ASCII outputs to printers and dot marking equipment
