Rockwell 1756-L75 compatibility with older IO Modules
jawad rasool
Feb 2012
Lahore
51
Hello and Good Day All,
We are planning to upgrade controller (from L55 to L75) for a Redundant ControlLogix based system. Following is a brief description of the system architecture;
i) Two 7-Slot Chassis which include;
------- Slot 1 - CNB Module
------- Slot 2 - 1756-L55
------- Slot 3&4 - SRM Module
------- Slot 5 - ENBT Module
------- Slot 6&7 - N2 Filler Module
ii) Two Remote IO Racks: Each Rack has one CNB Module following IO Modules
------- IB32
------- OB32
------- IF16
------- OF4
------- HSC
------- IR6
Please share your valuable suggestions on below points;
i) Either we need to replace the old IO Modules with latest ones or the old IO Modules will work fine with L75 and there will be no compatibility issue both in H/W and firmware.
ii) Will the old CNB module will work with L75 or there is any firmware upgradation is required.
iii) Previously SRM Modules are used for redundancy, what would be the better either to stick with SRM or upgrade to RM2 modules.
Looking forward a cooperation from you guys.
You need to provide the actual firmware of each module and the version to be used in the new controller. RA always suggests to update firmware to solve any known bug.
Please provide the CNB series (CNB/A, CNB/B, CNB/D...)
SRM is not compatible with L75. If you plan to use version 24 or newer, you have to use RM2.
You can go to Compatibility & Downloads section on RA website and use the Compare Products link to verify your hardware.
Hi Guys, Here I have started to work on some difficult task, I hope I will get solution here. we have ABB CI-840 Master IO Module needs to be...
598
Hi Guys, Here I have Started to work on some difficult task I hope I will get some solution here. I wanted to communicate ABB CI 840 IO Master...
575
Hi all. I'm having a hard time figuring out which cable goes with which module from Rockwell documentation, and my local Rockwell representative...
833
I have a spec that requires cable redundancy whether or not it makes sense. Also, I have to have redundant Processor Chassis where only one is...
3,193
Hi Guys.... I am facing one issue. PLC Controller i.e. 1756-L74 is now showing the error as T03:C16 IO connection Failure.... What can be reason...
1,598
