EGD Communication in PAC Systems
jawad rasool
Feb 2012
Lahore
51
I'm dealing with GE Fanuc PAC Systems (Rx7i and Rx3i).
There is a Rx7i based Main Rack and another Rx3i based Remote IO Rack.
I've to access the information of DI Modules in Remote IO rack from Main Rack via EGD. Can someone let me know what steps should I perform?
First you'll need to enable/install the EGD component in both your processors.
On the PLC that you wish to monitor, create a Produced Exchange. You'll be asked to define the data (or tags) that you want to make available to another PLC. Look at the object inspector where you'll define the broadcast type and possibly the destination IP address.
On the other PLC, create a Consumed Exchange and duplicate the information that is in the previously defined Produced Exchange you created. Also complete the objects inspector fields that are requires (source IP address,etc).
And of course you can reverse the produced and consumed exchanges with the same PLCs.
That's the basics of it but they can be temperamental in that if not properly defined, the s/w won't tell you what is wrong - it just won't work.
Hi all, I've two Rx7i redundant racks (RMX based redundancy) and two ENIU Rx3i based Remote IO racks. Both Remote IO Racks have the same HW...
1,613
I need to communicate to Mark-6 controller with my cpu364 ge fanuc plc through EGD. what are all the points i have to consider and what are all...
1,954
Hi All, having a bit of a hard time getting EGD communications working on Emerson CPE310. SO far i'm just trying to configure 1 Exchange of...
441
Hi, Wondering if anyone has had experience/knows how to modify the multicast address of EGD Data being produced. My PLC has Producer Id...
1,975
I have a project where i have two rx3i plc systems seperated by fiber with fiber\ethernet media converters. Both processors are IC695CPE305. My...
1,135
