IO Link Sensors
Maxkling
Mar 2011
Atlanta
511
I am looking for some current and voltage transducers that are IO Link ready. Only options I have found are standard analog transducers and using a converter to IO Link. Both are just standard 0-50 amp for current and 0-277 vac/vdc for voltage.
Anyone have any suggestions?
Hi, Do any of you use "IO-link" sensors communication with micrologix or compactlogix? What is your experience with "IO-link" sensors? BR, Wiktor
2,495
Good afternoon, I have a problem communicating with a system, I will explain it briefly. I have a HIS -ML17- CTBH monitor connected to an...
448
I'm struggling to get an FR-E800SCE to work on CC-Link IE TSN. I'm sure the issue is with the drive, when I plug in the network cable I get no...
122
Hi everybody, I would like to know if anybody here has already programmed with a LR-TB keyence on Io Link on a Rockwell PLC? And perhaps have...
105
Hi everybody, Is anybody here still have programmed a Keyence sensor LR-TB2000CL and used it as io link material in studio 5000. I would like to...
116
