Display is the last thing that you should be worrying about right now.
The network is the real issue.
It looks like you are mixing two ring protocols on a single network with devices supporting one or another but not both.
As I stated, you can't enable DLR (supervisors) unless all ring participants support DLR. This is not you your case, drives most likely can't support DLR.
So DLR (and DLR tool) are out of picture. Also please note that not all Stratix 5700 support DLR.
STP or RSTP can be used between switches, but these are not device level protocols, these used for switches.
Controller and ETAP don't support spanning tree it for sure.
I am sure that drives most likely can't support spanning tree directly.
So your network may appear to work, but in reality they just in the mode there one failure will cause control loss at best.
Networks are not Lego sets, then should be designed.
