Rockell PLCs summarized "for dummies"
AlfredoQuintero
Feb 2015
Yokohama
1,544
Hello.
I have a customer who has a 1769-L16ER-BB1B fw v 32.011 PLC. They use this to develop their own EtherNet/IP adapter, the development process for this EtherNet/IP device is very well advanced.
I need to provide them an easy selection guide for other Rockwell PLCs, which shows in a "for dummies"" format their PLC in comparison to other Rockwell PLCs (less capable and more capable), to figure out if there is something that is significantly better than what they have. The customer is even willing to consider ControlLogix if the performance with respect to ConpactLogix is significantly higher.
I cannot find a summarized table of Rockwell PLCs for selection. Does Rockwell have a knowledge base document freely available, or has somebody like a Rockwell distributor come up with something easy that lets see in a simple and comparative way the different options available?
Thanks.
Hello.
Thanks.
Here is a selection guide which might be of use: https://literature.rockwellautomation.com/idc/groups/literature/documents/sg/1769-sg001_-en-p.pdf
Thanks very much. I find this information helpful.
Your customer should also be testing with a Guardlogix PLC. Though their adapter may not use CIP Safety, it will have to co-exist with CIP Safety devices. The Guardlogix's safety scan is of higher priority that the non-safe device scan. Years ago (mid 2000s when CIP Safety was introduced), I experienced some problems with adapters that could not co-exist with the safety scan.
If your customer is working with the ODVA then I may just preaching to the choir but its something to be aware of.
Or there is an alternative to this? I suppose there are many but I've only seen put/get Can you for example set up a new plc and connect it to an...
289
I have a client who periodically experiences network communication issues. Sometimes when I VPN into the site, their SCADA systems will flash comm...
158
Hi, Seeking consultation on an implementation matter, and have a question about Modicon Compact 984 communication through RS485: Three Modicon...
196
I have been looking to this and thought I'd ask for input from others before I take it in a wrong direction. The guy who used to set these up...
397
I want to pick up an Allen Bradley PLC so I can practice writing programs. I have 10 years as a maintenance tech and a good understanding of...
227
