MSG Instruction
Apr 2012
Pune
I have to communicate between 1756-L61S and L73S.
Is it possible to add the L73S Controller in the I/O Configuration tree of L61S..?
We are using one EN2T module in L73S and One ENBT module in L61S.
Is it possible to communicate between these two controllers using MSG Instruction by adding L73S in L61S..?
Thanks in advaance.
While this is true, It still does make a lot of sense to put the controller on the IO tree, so people who maintain the structure long term can see an IO Error. I guess it depends on the local plant culture.
Yes, it definitely makes things simpler, I just didn't want to comment for sure because I don't have any experience with the Safety ControlLogix controllers.
86
Hello all, I am currently trying to establish a message instruction to pass data from a 1756-L73 to a 1756-L71. My communication path from the...
348
Hello Friends I am trying to connect to a Zebra printer. I can print the label with hyperterminal both by RS232 and TCP/IP. Now, I am trying to...
276
Can Anyone tell that How Msg Instruction comes under Unscheduled communication and How System Overhead time slice(SOTS) function connected to it...
968
Studio5000, V31 I'm Messaging a MassFlow Meter, specifically to pull the Engineering Units (units of measure) for 6 instances. Basically, do I...
1,203
