RS Logix 5000 Quick Sart Menu
Andy Veitch
Oct 2012
Oxfordshire
26
Looking for help on this one just to try to tidy a few things up.
On the quick Start menu are all the programs/ Projects I have opened.
How do I clear the ones I don't want out.
Can't seem to find it anywhere
I'm thinking it must be in some sort of Register.
Welcome to the site
I am interested to see the response
Personally I turn the quick start off or ignore it
They are stored in the registry in the following location:
HKEY_CURRENT_USER\Software\Rockwell Software\RSLogix 5000\Recent File List
Logix stores the 10 most recent programs opened. As you open new ones, it will clear out the old ones. If you don't know what you are doing with the registry, then don't mess with it.
The other option is to rename the projects you don’t want on the list and then try and open them, as it can find the program it will give the option to remove the link. Personally I would just ignore them and use Open Existing Project.
Welcome to the site
And how does one turn it off?
I had to reset mine a couple days ago to clear a bug, now everything is back to default. (cntrl shift while starting).
Seemed like it used to have a tick box for "don't show quick start" before. BUt I don't see it anywhere now.
found it in tools options application "show start menu"
now to find out why horizontal scroll stopped working....Shift +Scroll does nothing now.
So I have a PID loop on an 1756-L61 running V17 software just for background. Also the PID PV is a pressure transmitter and the CV is speed sent...
893
I'm creating a new thread for this because I can't seem to find the relevant info in my documentation. I remember how to run online edits for...
6,198
This may be a simple question. When I have my curser on a bit and I want to find the next instance in the program where this bit is being used is...
5,580
140
