Problems with resizing of the graphics in InTouch HMI
NathBarreiros
Jan 2021
Ecuador
Hello!
I have a question regarding the HMI in InTouch, almost a month ago I made an HMI and I have not used it again, now I need to make changes, however; making the slightest change on the screen, changes the resolution of the graphics when I see it in Run Time mode, does anyone know why this happens?
This is the visualization I had at the beginning, in online mode.
http://www.plctalk.net/qanda/attachment.php?attachmentid=57472&stc=1&d=1614147546
When I am in edition mode, from there it can already be seen that the graphics are somewhat extended.
http://www.plctalk.net/qanda/attachment.php?attachmentid=57473&stc=1&d=1614147546
Then when making a change in any part of the screen, it ends up resizing the graphics of my screen. This is a headache, changing sizes again and such ....!
http://www.plctalk.net/qanda/attachment.php?attachmentid=57474&stc=1&d=1614147546
Is there any solution to this?
i'm not the expert, but from what i have learned, you need to make sure that when you enter the development app, make sure your resolution is the same as when you created the project. every screen must be at the same resolution. also make sure that the monitor screen resolution is the same as the development resolution.
james
Edit the Intouch.INI file in your Intouch app folder to have:
ScaleForResolution=0
It may already be there as ScaleForResolution=1, so edit
This will hold the app windows to be 1024x768 (or whatever resolution you developed in), even if opened on your pc at 1920x1080
NetNathan,
i cannot speak for the poster, but thanks for the info.
i have had trouble in the past with this issue.
james
SINCE I found out this, it has made my development way life easier.
The only issue is when you use development and open it. The windows will maintain the correct ratio, but the full size window is now saved at your resolution.
So when you move it back to the original computer , you will need development license to convert the full window size down.
My app windows are 1024x768. So, after editing, I have to change my computer to 1024x768, open the app and then save back to set at 1024x768, then move back to original computer, or you will need development license on the original computer to do same.
Another file that is a lot of help is "ww_wdws.ndx". This file tells you the name of the windows by the numbers you see, I have been able to get rid of windows with startup issues by deleting them from this file to keep them from loading
NetNathan,
james
Hello. I appreciate the insights here and the willingness to share. I've got a lot of Rockwell experience, but my Siemens experience is...
130
Currently a student, so somewhat new to this. But working with an AB 2080-LC50-24QWB, CCW version 21.01.00. CCW will connect okay to the Micro850...
243
Hi Everyone, I have a customer that needs a CQM1H (CPU51) replaced. They purchased the processor new-old-stock from a source they found online...
320
Hello all. I am trying to create a project to download to my CPU312 (312-1AE13-0AB0) and I can't get it to add this device. The device and article...
21
1,320
Hi Guys, I am a new member and this is my first post! I have a little PLC experience but it is mostly with siemens logo and using ladder...
840
