PlantPAx P_DIn vs P_Alarm Block usage
zackscriven
Sep 2017
Rancho Cucamonga
Hi! I am working on my first PlantPAx control system. I have a level alarm low switch that I am questioning if I should simply use the P_Alarm block, or use the P_DIn block and feed the output from that into the P_Alarm block. Has anyone dealt with this before and can provide some insight? THanks!
We typically use the P_Din block and configure that to use the alarm block. Will post some screenshots tomorrow...
Rob
I just use the P_DIn block by itself. Then alarm on TgtDisagree = 1.
Hello, i need to use P_Intlk and feed the Status interlock OK bit to a P_DOut block. However, there's 17 interlocks for this output. How can I...
108
Hello All We have 3rd party vendors that run on older versions of PLC (Plc2.0) while we run the main system using plantpax and PLC 3.5-10. Plantpx...
92
Dear Members, Hello, we are working on a project and facing an issue with the plantpax 5 PMTR library, we have a bidirectional motor, which has 2...
241
The PMTR has a timeout parameter for run feedback during a start, but once the motor has been running for a while and loses that run feedback (to...
223
Hello, I am upgrading some custom AOI's for a customer that was using plantpax 3.5 they are moving to Pax v5. In their old AOI's they were...
535
