Do you know any Electric Actuaters capable of withstanding 180 degree F
Rob S.
Sep 2008
Maryland
739
Good Evening ,
Do you folks know of any Electric Actuaters that can handle about 180 Degrees F ? What are the common brands of Actuaters ?
Thanks in advance ,
Honeywell Herculine 2000 claims temperature rating to 185 Deg F (85 Deg C), but it is an ON-OFF actuator only.
The electronics used for modulating control bring the temperature rating of the 2001/2002 down to 170 Deg F
Rs485 module then 2 wire belden 9841, modbus network picking up electric meters. Does this need to be wired as a ring or a radial? Thankyou
90
Hello PLCS.Net Forum, First time posting. Let's assume I am a novice. BASIC PROBLEM: My servo/linear piston is no longer zeroed to the...
213
I have an old PLC (circa 2007) consisting of Telemecanique/Modicon/Schneider Electric devices. The system has developed errors and unfortunately...
230
Hi Friends, I am facing a problem with encoder adjustment in Sew Electric Cylinder CMS71L. encoder using is Sick Hiperface Drive is MOVIDRIVE...
17
784
Hi, I am stuck with these SE cartridges, I am trying to add a second serial port rs485 to a M221 PLC. What is the difference between TMC2CONV01...
116
