FB programming simulator
100 MOhm
May 2004
Syracuse
18
I am looking for a programm/software with a plc simulator. We just installed a new machine for a customer and because all programming is done as Function Blocks (we are from Germany), the maintenance people are looking for a possibility to learn the programming. We are using the Concept 2.2. Now I am wondering if somebody knows a good and "easy" programm to learn programming with Function Blocks. By the way, I think they need to learn programming anyways :unsure: Thank you very much
If your looking to have your customer learn programing of the PLCs you installed in their facility, I would suggest setting them up with the actual programming sofware as a smaller version of the same make/model PLC. This will cut the learning curve short since they will be learing on the same equipment that they will be programming in the real world.
Just my opinion...
Mike
The Moeller XSoft product has a very complete simulation mode. It is based on CodeSys which should be much more popular in Germany than here in the states. I'm not sure if all of the CodeSys products contain the simulation feature or just the Moeller.
Thanks for your answers. As I set him up with the plc software running on the machine, I determined that there´s a long way to go, till he even understands the entire thing :confused: . Did someone ever get the plcs.net training dvd´s from here. Is it a way to bring him a little closed to what´s going on in/with a plc ?
New to vfds. I put in parameters. IP, but I get ethernet flashing and link solid. What did I do wrong?
27
I'm been deciphering a program for a press here. I've gotten most of it deciphered using the manual to understand the instructions (first mitsu...
53
Hello colleagues, Some time ago I started my adventure with programming. With your help and the courses, things are starting to come together...
598
Dear All, I need a sample PLC program to count the output pulse of a mass flow meter so that a specific amount of mass (for example 100gm)can be...
84
Hi Please I have zeilo smart relay #SR2A201BD but I don't have it's programming cable. Can I use any general usb/rs232 converter? Or need...
80
