Index Integer Bit will not hold a value?
a11anjones
May 2009
oswestry
17
Hi , I have a small problem with one of the integers that is storing a setting that is adjusted by an E700 HMI and stored in the programme.
The program stores this value in an index integer called #n12:75 and this value is copied to n7:5 where it used by the program,but the integer #n12:75 continues to hold the value 2 whatever value I enter in with the HMI.
Within another processor on the same network there is a similar instruction that performs the same task the integer #n16:75 holds a value that is copied to #n12:75, then copied again to n7:5 where it is used for a similar purpose as above- but this one works fine. The 2nd processor was an addition to the system and had a duplicated program to that above when the system was extended, this is why the addresses are similar.
Do the addresses of integers on two different processors conflict, I dont believe that they do unless they are told to. The program seems logical and there does not seem to be any conflicts. I have noticed that on the main processor which is at the end of the DF1 network that the links are removed from pins 1 & 2 and 7 & 8 on the DH485 connector, does this affect instructions
Hi everybody. I got some problems about how to perform this task Now, I got an FB where I have this code snippet that looks like: L P##DBD_134...
1,129
I am using a function block that has a in/out parameter that is a structure. The structure has an array as one of the elements. I can index the...
736
Hi all, I have an Allen Bradley PLC which is connected to a Kinetix 300 drive. I have been using MotionView to adjust the different positions...
1,273
Sorry for the word salad title, I'm having trouble putting my problem into words. Basically I have two arrays of DINTs, both the same size...
29
7,967
Hi all, I'm working on developing a 90° valve actuator system that will actuate valves several hundred times for some testing. The PLC (an AB...
23
7,207
