I have a panelview plus 1000 that is failing to boot, on initial boot it will display all the software versions correctly but then everything except the bootloader and ospro will have a version of 00.00
I originally was restoring from the built in utility and selected the standard default backup. When attempting a restore from the bootloader it appears to run correctly but still fails to boot.
When booting into safemode it will make it to the desktop but isnt usable, i can ping the device when assigning it an address through dhcp however. I cant us the upgrade utility though because the panel doesnt show up in rslinx
Is there a way to reinstall the firmware from the bootloader? Anyone have a similar issue?
