Wireless sensor
you will need something to convert the wireless signal to contact outputs , wireless sensors usually communicate with custom displays or have reciever modules that have output contacts or 4-20Ma / 0-10V outputs
And what is your PLC? Different PLCs have different capabilities.
Asking such a broad question with so few details is why you didn't get many answers.
Thanks for the replies,
I have the CPU313C plc and my thought is the following, which I don't know if it is correct, I am thinking of connecting to an access point to the CP 343-1 Lean through the ethernet port it has and also connecting to the access point the pc. I'm also thinking of connecting the wireless temperature sensor to the access point, but I don't know which sensor to choose (probably one that will have an WIFI and battery for power supply)
anyone make such a thing? i see that ABB had something but it seems as if its been obsoleted. i would like to be able to make sure the lid is...
2,109
Pls I am a little bit new to PLC. I am to use PLC for remote monitoring and control. I will like to know if a wireless sensor can be used on a...
5,550
looking for small wireless system to transfer the state of a switch to a box 200m away. I have a switch sensor, which can be on or off, the...
3,862
Hey guys any one have any eperience with a level sensor that can convert it's signal to RF and broadcast to a reciever on a modem for longdistance...
3,151
Hello Y'all, I was wondering if there is any standalone solution to replace the ethernet cable to connect to a PLC? like perhaps a "Dongle"...
26
2,278
